Hello everyone... we have a catia translator for PC-Dmis, and I was wondering if anyone understands how or has ever brought in catia that has customer specified points? We have tried every option that we can see, but to no avail. Sometimes we get a dot where the point should be, but that point does not have any entities that generate the point when clicked on. We have used STEP files that have this capability, and to my understanding, Catia has the same. Any help or input would be appreciated
PC-Dmis Catia Translator Help
I don't use either but I could offer these ideas
just a thought ....did you try "wire frame" to capture the points needed in the model? They might show when selected this way.
Another option would be to have ENG output the critical points separately and merge that with the main CAD file. You might have to make each import a separate layer to select between the two.sigpiccall me "Plum Crazy"....but you only go around once!
Points on CATIA files
We are currently programming offline to CATIA v5 files. The customer has put POINTS on the CAD to indicate where holes will be. As you stated, these have no immediate use, but you need the info. In CATIA they contain the XYZ and Vector Values. In order to use them, or to get the data from them, if you open Vector Point, then drag a box around the point, ensuring only 1 point is selected, click on Create, this will then give you a Vector Point with the XYZ,IJK of the point. You can then use this info for Holes, or any other feature you need to create.I am a Mushroom................Kept in the dark and fed on sh*t!!!!!
by inspector212Is DCI working? I have some Solidworks models that I need to import. Would I be better off getting the iges files or having the solidworks files?
04-04-2008, 11:56 AM -
by CMM GuruHas anyone used the DCI for Catia V5 and what did you think about it? I am a fan and user of Catia as well as PC-DMIS. Our company is making the move...
02-06-2012, 02:55 PM -
by RussLWas curious if anyone uses Catia V4 DCI.
Turns out we have been paying for it for years now on three portlocks.
Have never used it as far...-
03-09-2007, 01:56 PM -
by dirk goroskiWe just got the latest version of Catia 5, rev 18. Now I can't open new Catia models without converting them to an iges, which is something we're not...
06-25-2008, 01:24 PM -
by DmisDaveWhat is the difference? I am looking at being able to import a Catia Part as it is received from the customer. Right now to use a Catia model it is translated...
02-22-2011, 03:42 PM -
