Why when using autoplane does the probe tip seem to bounce into the direction of the plane (about 1-2 MM drop) after taking the last hit on the plane? It comes very close to crashing on the part each time. Is there something to toggle or change to stop this?
probe tip bounce
Try to check:
Prehit and Retract parametr.
type from keyborard:
PREHIT/ 7
RETRACT/ 7
or click F10 >Motion>Prehit Distance & Retract Distancesigpiclearn to fly, fly to live, or die...
________________________
PC-DMIS 3.7MR3 & 4.3MR2
MISTRAL 070705
GLOBAL PERFOMANCE 092008
Check and see if you have AUTOMOVE turned on with a small value. The automove is a set distance from the nominal position that the probe will move to before and or after the hit. If it is less than your prehit/retract value PLUS the probe radius, it will actually move closer to the part after the end of the retract move.sigpic
by JEFMANI had this kind of issue when I changed from SP600 to TP200. In this case, I have to reboot the controller after changing tool.
11-06-2009, 02:48 AM -
by acgarciaGood Morning All:
The part I am inspecting is mostly composed of auto points so that I can utilize the avoidance moves and then construct...-
09-14-2016, 12:48 PM -
by gcr6251Can some one explain to me just what these legs are on the start and Stop hits of this Plane. They are effecting my Pre-Hit. Can i remove them, or at...
03-02-2015, 02:42 PM -
by lcrowstonI am trying to measure a .08" wide seal groove in Z+, I am having no success, the probe retraction is too great and the probe tip bounces off the...
12-05-2018, 05:56 PM -
by operator1I'm making an auto cylinder with a diameter of .249 with 7 hits for 2 rows. Every time it goes to take the second row of hits, it errors out at the Circular...
10-16-2007, 08:10 AM -
