Scan: constructing circles from half-circle scans
  • Scan: constructing circles from half-circle scans
    Hey fellows I scanned 2 half circles and then tried to create 1 - 360 degree scan from them and it seems to be fishy. Here is my code, Thanks and War Eagle.
    SCAN1 =FEAT/CIRCLE,CARTESIAN,IN,LEAST_SQR,NO
    THEO/<0,0.2585,0>,<0,-1,0>,3.746
    ACTL/<0,0.2585,0>,<0,-1,0>,3.746
    CONSTR/CIRCLE,BF,2D,SCN1B.HIT[1].XYZ,SCN1B.HIT[2..59].XYZ,SCN18B.HIT[1].XYZ,SCN18B.HIT[2..59].XYZ,,
    OUTLIER_REMOVAL/OFF,3
    FILTER/OFF,UPR=0
    Last edited by Josh Carpenter; 10-11-2017, 09:50 AM. Reason: Please put some thought into your thread title.
    what are you trying to achieve doing this? the form of the two half circles as one? the position of the centre of the two half circles?
    Reason I ask is there are a few limitations to using the data from a circle scan or any scan and then constructing a circle out of it.
    I am sure someone asked about the same thing not too long ago and you may be able to search for it.
      I'm trying to get a circle diameter 1st and the form/circularity of a composite blade shank around 10 different diameters.
        CONSTR/CIRCLE,BF,2D,SCN1B.HIT[1..SCN1B.NUMHITS],SCN18B.HIT[1..SCN18B.NUMHITS],,
        FILTER/OFF,UPR=0
        Adjusted
          Soon as I finish running the part on my old program I'm going to try this. I'm trying to get away from a TP200 TTP and run these on a SP600M scanning head for more accuracy and profile/form
          • RandomJerk
            RandomJerk commented
            Honestly, I think the only thing you'll gain by making that switch is time.
            I'm going to make an assumption here - the scans you're doing are half circles, you need to get into it with different probe rotations? If that's the case, you may be better off doing them as 180° autocircles using adaptive scan. You'll still be able to do the above to make a full circle out of the two halves.
          • AuRules
            AuRules commented
            I have 2 - TP200 only and 1 SP600M. I not up on the term adaptive scan. Does it require a certain probe setup or a certain version of software? Time is part of this also.
          • AuRules
            AuRules commented
            The LK machine I'm on now the controller does not support scanning, my Global does. So I'm trying to create a program that I can transfer from the LK to the Global for faster time and better results compared to taking 18 points around on each diameter.
          Adaptive scanning is a measurement strategy that may not show up if you don't have a scanning probe as the active probe. You could create the program on the non-scanning machine, transfer it, then edit the measurement strategy on the scanning machine. It's the second tab from the left in the auto feature window.
            So you also can a tip angle change inside the feature
            • RandomJerk
              Nope. Note the Start/End angles in the snippit I posted.
              I just did this exact thing yesterday trying to troubleshoot an assembly issue for some large parts.
            Since these blade shanks are made of composite I need a clear picture of the diameter and the form on 360 degree so we can make sure the form is not causing the leaking during test flight.
              Here's how I did it last Friday, I deleted a lot of stuff out.
                TIP/T1A-20B0, SHANKIJK=0.0006, -0.342, 0.9397, ANGLE=0
              FOD1       =FEAT/CONTACT/CIRCLE/ADAPTIVE_CIRCLE_SCAN,CARTESIAN,OUT,LEAST_SQR
                          THEO/<0,0,0.2>,<0,0,1>,12.3725,0
                          ACTL/<0.0002,-0.0003,0.2>,<0,0,1>,12.374,0
                          TARG/<0,0,0.2>,<0,0,1>
                          START ANG=180,END ANG=360
                          ANGLE VEC=<1,0,0>
                          DIRECTION=CCW
                          SHOW FEATURE PARAMETERS=NO
                          SHOW CONTACT PARAMETERS=YES
                            NUMHITS=18,DEPTH=0,PITCH=0
                            SAMPLE METHOD=SAMPLE_HITS
                            SAMPLE HITS=0,SPACER=0.25
                            AVOIDANCE MOVE=NO,DISTANCE=0.375
                          SHOW HITS=NO
                          MOVE/POINT,NORMAL,<10.0000,0.0000,10.0000>
                          MOVE/ALL,<10,0,10>,TIP=T1A20B0,SHANKIJK=0.0006,0.3421,0.9397,ANGLE=0
              FOD4       =FEAT/CONTACT/CIRCLE/ADAPTIVE_CIRCLE_SCAN,CARTESIAN,OUT,LEAST_SQR
                          ACTL/<0.0002,-0.0021,0.2>,<0,0,1>,12.3741,0
                          START ANG=180,END ANG=0
                          ANGLE VEC=<1,0,0>
                          DIRECTION=CW
                          SHOW HITS=NO
              SCN1       =FEAT/SET,CARTESIAN
                          THEO/<0.0088,0.0096,0.1839>,<0,0,1>
                          ACTL/<0.0091,0.0085,0.1999>,<0,0,1>
                          CONSTR/SET,BASIC,FOD1.HIT[1..FOD1.NUMHITS],FOD4.HIT[1..FOD4.NUMHITS],,
              FOD7       =FEAT/CIRCLE,CARTESIAN,OUT,LEAST_SQR,NO
                          THEO/<0,0,0.1839>,<0,0,1>,12.3725
                          ACTL/<0.0002,-0.0011,0.1999>,<0,0,1>,12.3728
                          CONSTR/CIRCLE,BF,2D,SCN1,,
                          FILTER/OFF,UPR=0
              DIM LOC1= LOCATION OF CIRCLE FOD7  UNITS=IN ,$
              GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH  HALF ANGLE=NO
              AX       MEAS    NOMINAL       +TOL       -TOL        DEV     OUTTOL
              Z       0.1999     0.1839     1.0000     1.0000     0.0160     0.0000 -----#----
              D      12.3728    12.3725     0.0025     0.0025     0.0004     0.0000 -----#----
              END OF DIMENSION LOC1
              DIM CIRTY1= CIRCULARITY OF CIRCLE FOD7  UNITS=IN ,$
              GRAPH=ON  TEXT=OFF  MULT=1500.00  ARROWDENSITY=100  OUTPUT=BOTH
              M       0.0016     0.0000     0.0025     0.0000     0.0016     0.0000 ------#---
              It yielded this for a visual:
                I used your construct technique, I have not yet run a part but I did try the Analysis Window and it showed 2 circle, form was great (haha) but it should have only shown one. A little frustrated.
