Running PC-DMIS 2013 MR1
Hello! The boss wants a pretty colored report for dimensions. Essentially, if the dimension is in, green for good, red if its out, but they also want the dimensions to be colored yellow if they are almost out. I understand this is easy with the Graphic Display Window, but they want the actual print out Text-Only dimensions to have three colors. I can do this where IN is green and OUT is red, but how do I add the "almost out" functionality?"
I would assume I would have to use variables to check if the tolerance - deviation (using absolute value) is X, set dim color yellow, but I can't find any examples
Your assistance is appreciated
