E179 error troubleshooting question
  • E179 error troubleshooting question
    Ok, I know this error is covered in another post, but I just wanted to get an answer from what one of the post said for troubleshooting the error. It said, "to delete the probe calibration file data". If I do that, will I have to re-establish the probes and angles all over again in the programs? Or will they still be saved in the programs? The company is having a technician come out from hexagon tomorrow for the issue. I'm just trying to get the CMM running for today. Would I have to delete the results files and .prb files?
    The results files is nothing more than a text file so you can access the results 'not in Pcdmis'. Deleting the results file will have no effect on Pcdmis. The probe calibration data that Pcdmis uses is in the probe file itself.
    • SI_GUY_29
      SI_GUY_29 commented
      Where do I access this probe file? All I see is the Copy-Current probe tips file. Also, If I gain access to this file and delete the probe data. Will I have to re-establish all the probes in the programs?
    • bigtallanddopey
      bigtallanddopey commented
      it depends where it has been saved, check EDIT > Preferences > search path to find out.
      Yes, if you delete these you will have to re-create all your probes, not in the programs if you call them exactly the same names and re-create the same angles
      Have you tried re-setting all the tip data when calibrating? there is a button to do so in the calibration window.
    • SI_GUY_29
      SI_GUY_29 commented
      Are the files that I need to delete listed as ex: 2mmx20mm.prb?
    Your programs will still look for those probes/angles, only they will be red if that probe doesn't exist any more or angle is not calibrated.
    sigpic...engineering
      Then all when you click on Mark Used, the probe file will populate with the tips/angles used in that program. If you see an asterisk next to the tip/angle name, then it means that it was just created and not calibrated yet. Those will be at the top of the list. Just calibrate them and all will be well.
      PC-DMIS 2016.0 SP8
      Jeff
        I will see if I can get this to work. Thanks for all your feedback, appreciate it.
