save AS popup
  • save AS popup
    Every time the program is done running, this save as window pops up, wanting my to save a prg
    B&S One
    PC-DMIS CAD v2014
    Romer Infinity
    I'm not sure, but in F5 there's a "save after execution".
    Does it happen after every program or only certain programs? Did this just start? Only asking because there could be a save command at the end of the program.
    • WolfMan
      WolfMan commented
      I couldnt find it under f5. Yes every program
    • Mikeg
      Mikeg commented
      Is there a save file code in the programs?
    F5 has a "Save measurement routine on execute", but I've never used it so I'm not sure.
      this is different, it wants to save as after it finishes the run
      B&S One
      PC-DMIS CAD v2014
      Romer Infinity
        Is it trying to save the program or possibly the report?
          http://www.pcdmisforum.com/forum/pc-...ation-variable
            I think its trying to save the report
            B&S One
            PC-DMIS CAD v2014
            Romer Infinity
              Check in your report window print setup. If you have output to file turned on and "prompt" selected it will ask you to select a location for the report file every time the program finishes
              Neil Challinor
              PC-DMIS Product Owner
              E: [email protected]
                Hello WolfMan,
                In the File | Printing | Report Window Print Setup, click on the report tab. In the report tab, if the prompt button is selected, PC-DMIS displays a Save As dialog box through which you can choose the destination file for the report.
                That is the reason Save As dialog is displayed after execution.
                Hope this helps.
                Regards,
                Krishna Chaitanya Velisetty
                Metrology Software Applications Specialist,
                Hexagon Manufacturing Intelligence.
                • cvelisetty
                  cvelisetty commented
                  Yes Neil. I saw your comment once after I updated my note.
                  Thank you for your quick input on the query. (y)
                • WolfMan
                  WolfMan commented
                  Yes, I have it selected to Prompt. So, what should I select it to? I want the program to stop, and nothing to print or save as. And when I wish to print, just click the print icon.
                • cvelisetty
                  Just remove the check box for output. It doesn't print anything.
                I think I got it ,thank you.
                B&S One
                PC-DMIS CAD v2014
                Romer Infinity
