Reporting to Excel
  • Reporting to Excel
    Hello,
    When I try to report my parts results to excel and try to define its location, it always reverts back and saves the csv file to the location at which I have the program saved?
    Is there a reason as to why this is happening? There are print commands within the program, several of them, and as they are not my programs but "the motherships" I don't know what should be written in them to make this work.
    It reports PDF Files perfectly.
    Thanks.
    Cian
    saving to excel works a little different to the print commands, There will be a command in the program, something like this :
    EXTERNALCOMMAND/DISPLAY ; C:\Program Files\WAI\PC-DMIS 2012\Wizards\PCD2EXCEL.EXE A
    You have to configure where it saves to, go to File > Export > Excel
    a screen should pop up, where it says to Excel, check the file path. If it is wrong press the configure button and change it your destination.
    Hopefully that works, its been a while since ive actually set this up.
    • nooners4
      nooners4 commented
      Hi BT&D,
      As I do not have excel on eacch of the CMM PCs I can only output a CSV file.
      Is the process the same or does it differ if I am to report a CSV?
      Thanks
    • bigtallanddopey
      bigtallanddopey commented
      Should be the same, there's just a tick box in there to change from excel to CSV, but I would think yours is already set to CSV. Just guessing the file name isn't correct
    ASSIGN/FPATH="C:\Program Files (x86)\WAI\PC-DMIS 2012 MR1 (Release)\Hubs\HUBDATA\7547\SN_" + C4.INPUT + ".rtf"
    PRINT/REPORT,EXEC MODE=END,$
    TO_FILE=ON,OVERWRITE=FPATH,$
    TO_PRINTER=OFF,$
    Then go into your print/command and check rtf, that will open up in excel just fine.
      this does not help nooners4 but using the internal excel output (starting with v2014?) excel is not needed to generate the excel fie. Excel is still needed if using the wizard to generate the output.
        Originally posted by nooners4 View Post
        Hello,
        Thanks.
        Cian
        As I read he was just sending it to Excel and create a location to put.
        • bluenowhere2
          Excel output - can I edit
          by bluenowhere2
          Hi
          Recently started using excel reporting for in-house Engineers to check measurements (pdf for customer). When I check results there are several...
          07-09-2015, 04:05 AM
        • CRowse
          Exporting to Excel
          by CRowse
          So I've run into this problem recently where no matter what I do, PC-DMIS exports my Excel files with the ending "017" instead of starting them...
          11-26-2018, 11:49 AM
        • Darrollh
          PC-DMIS to Excel
          by Darrollh
          Good morning,
          I have accepted a position with Siemens where I am required to work both on and off-line. For off-line, I am setting up my Laptop...
          12-23-2018, 12:09 PM
        • khanh.nguyen
          Pc-dmis to excel file
          by khanh.nguyen
          How can I export to excel some specific cells in the Sheet? For example, I just need everything in ID column and MEAS column. Can we do that with PC-DMIS...
          05-11-2016, 01:57 PM
        • Randy P
          load Excel file
          by Randy P
          I want to load Excel at the end of my program and a file called report.xls when excel loads how do I do that? I can get Excel to start with this command....
          02-16-2007, 10:02 AM
