best analog scan
  • best analog scan
    I am struggling with this particular feature and i am not entirely sure why. I had it scanned 3 times by linear open scans then combined them in a constructed feature set. I dimensioned that as a profile of a surface, but it was not working properly as it was not reflecting the changes made on the cnc machine. I am trying to find the best scan for the notch portion, but i was wanting some input on what the best option would be. the notch diameter is 1mm, so it is fairly small, which may contributing to my struggle. notch.JPG
    Just because I act like I know what I am doing, doesn't mean that I know what I am doing. It's your fault for assuming...
    your alignment is absolutely key to this reporting properly (especially is you're trying to report form AND location). can you please post a better pic of your part so we have a better idea of what you're trying to measure as well as your code?
      What size probe are you using?
      If you are trying to compare a machine offset to the model I personally would go in and take a series of individual points. Then I would dimension those individual points using "T" value. You could then create a scan set from the points and dimension that as well if needed.
      Jesse Krook
      • daberger
        daberger commented
        i would rather use an analog scan due to time constraints if possible.
      • daberger
        daberger commented
        it is a .5mm probe
      i will get some code and a picture... this feature is called back to my C|A datums, C (c is a constructed midplane of the flat on both sides of this part) being the rotation about z and A being the level and origin for Z.
        side view.JPG here is a side view of the part the angled flats are combined to make a midplane that rotates about Z plus to y plus.
        The top flat is the a datum and is leveled along z
        X and Z origin are set off of Cdat and Adat respectively. X origin is set off of the Bdat (cone feature)
          here is how it was setup but was not reflecting any changes made from part to part notchscan.JPG
            here is my alignment, the B datum is the cone. the angled planes and notches are cut in with a form tool from the sides and a form tool puts the cone together. i think location is the bigger variable herealigment.JPG
              I thought about trying a freeform scan, but would like to do something more precise if possible.
                Why can't you do a linear open scan?
                Scanning around that sharp corner you really need to slow the scan speed WAAYYYYY down. Your using a .5 mm probe in a 1mm diameter. How many points is your scan actually picking up? 20-30 depending on your settings? I would get a .3mm ball if I were planning on scanning that. Also time constraints? You cant go in there and probe 3-4 points to feed data back to the machinist? The same tool cuts the entire surface. You should be able to decipher from 4 points on that diameter if the CNC is off in any one direction.
                Jesse Krook
                  i am not sure why the linear open would not work. i have a patch scan setup that is working now. i just had to play around to get the speed slow enough to where it would repeat. good point on the 3-4 points since the tool cuts the whole surface. i did not think of that... just me over complicating things... Thanks for the help!
