Hi,
I have a program that measures on a pitch circle some nubs. After this measurenent, the same thing has to be measured, but on a smaller pitch circle. I have made the dimensions all variable, so I think I can throw it in a loop and change only the diameter, however, I also need to rotate all the alignment 30 degrees in the loop.
Does anyone knows how to rotate the alignment in the loop?
