I am running a DEA GAMMA "or would be" I have a error light on on one of the controler boards. It's the OV T ALL light. ANY HELP???
CMM startup
Just guessing, but it might be the OVER TRAVEL, ALL AXIS. If you can move the machine, get it off the hard limits and try again. You may have to move it by hand, so be careful. If you have to move it by hand, apply the pressure as close to the 'hardware' as you can, meaning don't push on the leg of the bridge that is opposite of the drive unit, that could warp the machine, you would want to push on the leg that is trapped in the guide, and push right next to the drive.sigpic
I also run a DEA GAMMA; Tutor P controller & TU01 jog box.
Not sure what board you're talking about, but it sounds like an overlimit or over travel error. You might be telling the head to go somplace it can't reach; outside of the envelope of the machine.
Like Matt said, you may have actually over travelled one of the axis, and may have to "help" it a bit.Last edited by Rick Coleman; 04-11-2006, 09:33 AM.sigpic:eek: Bring out the comfy chair!:eek:
by dccfreakDoes anyone have a DEA machine? I just acquired a scirocco, but I am totally unfamiliar with their jog box. I have noticed that the X and y axes are...
06-02-2006, 11:34 AM -
by djone368does anyone know what causes a lag error
thanks-
11-21-2006, 09:59 PM -
by Jimmy Hirschnever seen this un' before ................... anyone ???
05-17-2013, 01:25 PM -
by Robert DavisBrown & Sharpe Validator
PC-DMIS 3.5 MR2
One of my air hoses to the Y axis that supplies the air bearings broke. I ended up...-
05-18-2006, 07:38 PM -
by B. JacobsIs it posible to scribe a line using the CMM. I am using a PH10m head with TP20 probe. If so how would I go about it? Tanks ahead of time
03-31-2006, 08:07 AM -
