Set as Master
  • Set as Master
    I could use a few of your thoughts on this problem. Currently I am in the process of modifying assembly sub-components programs to use the current stampings as masters for gage modifications.
    My problem is that after I F9 my features, set to Master, execute the feature, and create a new dimension box for the "Master" feature. The measement deviation "should" be close to zero. When I run my program through the deviations will be way off (up to a full mm). If I create a new dimmension box right after the current dimm. it will be close the "master" nominals.
    I haven't been able to determine what is causing the numbers to change. Any help will be greatly appreciated.
