Offset point
  • Offset point
    I would like to construct an offset point from existing point. The point is on round surface and I want to make another point that is 5.5 mm from existing point in nominal direction. I was trying with offset point function and vector distance point function but no success. There is no vector offset point function (select a point and write the offset and the point is created in the direction of nominal vector) in PC-DMIS. I do not want to write the I,J,K vectors to construct this point. Need some help to make a easy simple solution.
    I've not done a lot with those methods of construction, but the few times I tried them.... yuck
    So, I just fall back on the old GENERIC point
    P001       =AUTO/VECTOR POINT, SHOWALLPARAMS=YES
                THEO/0,0,0,0.5773503,0.5773503,0.5773503
                ACTL/0,0,0,0.5773503,0.5773503,0.5773503
                TARG/0,0,0,0.5773503,0.5773503,0.5773503
                  THEO_THICKNESS = 0, RECT, SNAP = NO ,$
                  AUTO MOVE = NO, DISTANCE = 7
    P002       =GENERIC/POINT,DEPENDENT,RECT,$
                NOM/XYZ,0,0,0,$
                MEAS/XYZ,P001.X+(5.5*P001.I),P001.Y+(5.5*P001.J),P001.Z+(5.5*P001.K),$
                NOM/IJK,0,0,1,$
                MEAS/IJK,0,0,1
    DIM D001= LOCATION OF POINT P001  UNITS=MM ,$
    GRAPH=OFF  TEXT=OFF  MULT=1.00  OUTPUT=BOTH
    AX  NOMINAL    +TOL     -TOL     MEAS      DEV    OUTTOL
    X     0.000    0.000    0.000    0.000    0.000    0.000 ----#----
    Y     0.000    0.000    0.000    0.000    0.000    0.000 ----#----
    Z     0.000    0.000    0.000    0.000    0.000    0.000 ----#----
    T     0.000    0.000    0.000    0.000    0.000    0.000 ----#----
    END OF DIMENSION D001
    DIM D002= LOCATION OF POINT P002  UNITS=MM ,$
    X     0.000    0.000    0.000    3.175    3.175    3.175 -------->
    Y     0.000    0.000    0.000    3.175    3.175    3.175 -------->
    Z     0.000    0.000    0.000    3.175    3.175    3.175 -------->
    END OF DIMENSION D002
    DIM D003= 3D DISTANCE FROM POINT P001 TO POINT P002, NO_RADIUS  UNITS=MM ,$
    M     0.000    0.010    0.010    5.499    5.499    5.489 -------->
      Offsetting the alignment to the exact location you want and then creating a point would work as well.
