Heres my problem. The part I'm working on has a flat machined surface, it 12x12 inch's. Theres cores about every 2.5 inches around the edge's all the way around. I need to check to see if the part is concaved in-between the cores so I picked up a 3 point plane in-between each core then did an alignment and set Z to the plane. I then took single points on the area I just set Z to and my numbers were all over the place. It was like they were going down hill from core to core. So Then I did a 4 Point plane and my numbers looked much better. Now I'm wondering if I did something wrong in the programing.
3.7 MR2.
3.7 MR2.
