Hello lads,
I am having the following two problems for past two days.
I Am using 2013 MR1, PH10 SP25 & the styli length was 2by50 mm
Problem 1:
Encountering the following error :
ERROR CE ,S%1 ,TR_CE .0X1400003f Weight Balance routine timed out
It happens during partial calibration after the probe rotates.
In the program that uses 7 probe changes, it only happens on one of the probe builds.
The probe rotates from A0B0 to A45B0 to A45B-180 to A45B-90 to A45B90 to A90B0 to A90B-180.
Nothing hits it, the probe is at the clearance plane and clear of any obstructions.
Problem 2:
Encountering the following error during full (scan) calibration
ERROR CE ,S%1, TR CE, 0X14000033 PROBE UNSEATED after the rectract movement.
the above error wasb poping out at last wrist angle rotation.
Both error are showing in same program at diffetent wrist angle change
I've been browsing this forum for past couple of days, unfortunately ain't got what i expect.
Any ideas are much appreciated.
