Running Brown & Sharpe / Global / pc-dmis 3.7 /I had a small probe carsh.and a message of ( ok/ shtdown) pop up/ after shutdown, tried to turn on the machine, START run normal, but when trying to start machine from joy box start botton , the green light in PHC10-2 clicked just for two seconds and gos away,
called technical support to do in houose investigate on cmm, the test was coming up with ( e_stop_relay).
machine was tested with all new :NEW PHC10-2 & PHC9/NEW PHC10 / NEW JOY BOX/ NEW RENISHOW HEAD/ TP20 WAS REPLACED WITH TP2/
and still same problem machine not working ,with same error message when tested,
Do you have any ideas on what problem could be,
Please, advise,
Thank you all in advance,
Please, advise,
