Hi everyone , I am having a problem with the speed of my cmm my programs and calibration runs slow, even with the speed up to 100%, what can I do to improve this?
Machine speed
Originally posted by Steve R View PostHi everyone , I am having a problem with the speed of my cmm my programs and calibration runs slow, even with the speed up to 100%, what can I do to improve this?
Is jog box speed control at 100%
Are you working in percentages or absolute speeds
is machine top speed set correctly ( F5> part/machine )
Goto to EDIT/PREFERENCES/SETUP or F5. Check to see if your absolute speed is checked, if your running % then this needs to be unchecked. If your running mm/sec then it needs to be checked. speed1.JPG(In Memory of my Loving wife, "Ronda" who I lost March 7, 2016. I love you baby.)They say "Nobody's Perfect." I must be Nobody.
My CMM top speed got itself changed due to a HM Calibration. A 9-12-9; it was pretty speedy before, but 20 years old. I was told that it needed to run a bit slower to avoid " oscillation" and also to meet the factory volumetric specification. The oscillation issue is due to wear in the drive system - motors, belts, rack & pinion gear lash and so on. Although, to my knowledge, it has never had a "hard crash", I never ran it at top speed - frankly because it made me nervous.
I believe it is possible to make my CMM run at its previous top speed ( which was too dang fast ) I don't ( obviously ) feel the need.
You don't mention the size of your CMM. The big older ones run still slower mostly due to mass & acceleration of the bridge. Just my 2 cents if the advice above isn't doing it for you.
Begs a question: Why isn't it SOP for HM technicians to state on the Calibration certificate what the ( certified ) max speed is ?
- 1 like
So, now I'm back to my first question...Has this always been a problem or has something changed?
The only other thing I know to check is:
From the PCDMIS Splash Screen "EDIT>MACHINE INTERFACE SETUP then click on the Parameters Tab and see what X, Y & Z are set at....Sheffield Endeavor3 9.20.8, Tesastar-SM, Leitz LSP-X1s & LSP-X1M, PCDMIS 2011 MR1
by WWhortonHow can I make this CMM go faster, I have proven out the program but it is so slow, any ideas. Thanks everything is at 100 % .
10-30-2017, 09:07 AM -
by TommyArrowUm... I have spent 15 minutes trying to find this answer on the forums... It seems like a stupid question but.....
In my f5 settings, the...-
12-06-2013, 11:07 AM -
by dwadeI am trying to solve some issues with people here that always turn the speed down on the jog box to around 50%. I have always told people to use the same...
02-06-2007, 03:59 PM -
by ADAM WALLACEI have a program running at 75 percent move speed. I need to slow the move speed down from the 75 because of false triggers moving in the z axis of the...
10-24-2013, 11:23 AM -
by kdatlaHi,
I have a LK CMM with a old controller, it has a jogbox that does not have speed control(I have to change the controller if I have to...-
10-07-2015, 04:52 PM -
