MOVE/POINT Disappearing
  • MOVE/POINT Disappearing
    I have come across an issue which I have never seen before and was wondering if anyone else has experienced this.
    After creating an AUTO POINT (Vector) I am then inserting a MOVE/POINT, however, whilst running this through, the CMM takes the Point OK but totally misses out the MOVE/POINT. The MOVE/POINT then disappears altogether from the program.
    I am wondering if this is just some setting that I have clicked on?
    Running PCDMIS 2011.
    Thanks in advance
    Is it possible that you are inserting the move/point within the auto-feature, rather than after it?
      It does this whether I insert an auto move point or use the controller to insert the point. The move point itself is indented as if it is part of the point, however, there seems to be no way of getting rid of the indent
      • giantslayer
        giantslayer commented
        Have you tried shutting down everything and re-starting it?
      What version of pc-dmis are you running?
      Cluster Fudge Sir!!!!
      • bfire85
        bfire85 commented
        He stated he is running 2011.
      • giantslayer
        Oh right I see it lol
      Go to:
      Edit > Preferences > Edit Window Layout > "Show moves" must be active (check mark).
      sigpicIt's corona time!
        If it's indented, like it's one of the hits, then that tells me that you have "Show Hits" turned on. Try turning "Show Hits" off, and then insert your move/point.
          Are you using groups?
          I've seen this sort of behavior in groups and with you saying it's indented makes me believe theres some sort of group there.
            I have done this. It seemed to work in a 'Measured Feature' (like a plane where you might need to avoid an obstruction) but it didn't work as expected if inserted in an Auto Feature if I remember correctly (never tried it in an Auto Point). Can you delete it out of your Auto Point code, and place it after that code?
