We have some concerns regarding executing a program created from cad. (1) Main concern is executing program closely enough in relation to how the hits were taken in cad after all ,we only have a manual machine). We have found that if we don’t take hits close enough from the cad to the master we get a message that says we are out of toll. But other times it will send you backwards in the program or also has added an extra point into the program. Is there a tolerance zone that we have to stay within. This quite difficult with a manual machine. Question is - can we realistically incorporate cad into a manual machine? (2) Do we have to be off-line when programming from cad? (3) Last but not least, is there a sequence that we must follow when creating program, ( example, when we probe entire cad and then execute program on master our t values are ranging .030 to .060 dev. But when we probe a cad surface and then executed that surface right after on master it seems to come out with more accurate results. Bottom line we don’t trust our numbers. Please advise.
Thank you
Trevor
Thank you
Trevor
