Large Sphere, Small Part
  • Large Sphere, Small Part
    So I have a family of parts(pucks) with a convex(out of) or concave(into) top surface.
    The CMM seems to have trouble accurately measuring this sphere,
    The Outer Diameter (OD) of the part 3in and 6in, with the a convex sphere with a 7.5in radius (poorly drawn but cannot post BP)
    Polar radius with an alignment doesn't work well because if the OAL is bad then the Sphere will automatically be bad.
    Tried taking hits along the x and y axis to construct circles instead of a sphere but still only sort of works
    This is also causing issues with the OD-Sphere intersection height since the sphere is not accurate enough
    Gage points seem to be effective, but not all BPs have them
    seems like I have a lot of partial, quick answers but nothing really accurate
    Thanks
    -CTC
    Does the sphere directly relate to the rest of the part?
    If you can offset in Z from the bottom, and then offset in XY from the OD (maybe 0) to "set" the sphere center, then you know what the radial values of any hit on the sphere surface should be.
    • Cheetos_The_CMM
      Cheetos_The_CMM commented
      So I "can" offset the Z axis to the theoretical sphere centerline but if the sphere was cut higher or lower than it was supposed to be the sphere construction is bad and the distance from "theoretical sphere center" would give bad readings.
      If the part was 100% perfect height that would work, but manufacturing is never perfect
    what is bad readings? If the part is the wrong height, wouldn't the sphere be in the wrong location? and wouldn't you want to know this? Otherwise, why are you inspecting it?
    Don't take my writing personally, I am just trying to understand the real question
    • Cheetos_The_CMM
      Sorry im relatively new to the pcdmis/cmm world.
      BUT, a bad reading would be if it was either too close to the center or to far
      The sphere doesn't construct very well, and the (x,y,and,z) readouts of a sphere constructed from a series of points (not auto sphere) are not accurate enough
      When I make a cylinder on the OD I construct lines to intersect the sphere so I can get a circle constructed, then take the z location of the circle and that gives me the information needed to tell the machinist to offset
      I need to know if the sphere has:
      A) a bad shape (if its an egg shape)
      B) if the sphere has the proper (Z)
    • Cheetos_The_CMM
      Im considering writing a loop function that will offset and will add or subtract the Z plane alignment and continuously do the math until the Sphere radius is good, but will time out after (lets say 20 tries) and give a reading for a bad part
      Basically do:
      lets say theoretical sphere center is (-6.5) from the zaxis (cmm plate)
      assign n=0
      start Loop 20times
      N=N+1 (make a counter)
      if N>11 goto Next
      If N=1,N=2,N=3,N=4,N=5,N=6,N=7,N=8,N=9,N=10,
      Assign V1=(N*.001)
      end if
      If N<11 goto END
      "Next"
      If N=11,N=12,N=13,N=14,N=15,N=16,N=17,N=18,N=19,N=20,
      Assign V2=-((N-10)*(.001))
      A1=Alignment Zaxis offset= -6.5+V2+v1
      LINE1: Distance from center to point 1
      LINE2: Distance from center to point 2
      LINE3: Distance from center to point 3
      LINE4: Distance from center to point 4
      Assign PNT=(LINE1+LINE2+LINE3+LINE4)/4
      if PNT,PR= undesired
      goto END
      if Point.PR= desired
      Goto Dimension
      Dimension
      Recall A1
      CONSTRUCT SPHERE (generic with variable PNT)
      (sphere dimesion stuff)
      END
      Loop End
    After aligning to the part, take a vector point at XY (0,0) and vector (0,0,1). Use this point to offset your Z.
    Offset your sphere measurement by this value (using Auto Relative Measure).
    So, if your sphere is THEO 0,0,-6.5, then use RMEAS to multiple features, selecting the vector point in the Z drop down.
    Just taking points is never going to be very good, because the surface is such a very small portion of a sphere.
    With points, your best bet is always to origin on the theoretical sphere and use polar radial points, just like doing a small arc radius, but in 3D.
    • Cheetos_The_CMM
      I will definitely try/do this
      Thank you!!
      -Cheers
      C
