Horizontal probe orientation change.
  • Horizontal probe orientation change.
    Hi everyone,
    I have an old B&S horizontal and I am trying to change theprobe to a "vertical" Position. Is there any thing I have to change other than “Edit, Preferences, Setup , Part/Machine tab, probe Head Orientation” A0B0=Z minus , A90B180 =Y Minus.? Do I have to do a manual Probe calibration for all angles? I am getting no where with calibrating the probe. What am I missing?
    B&S Oryzo
    PH10 TP20
    3.7MR3
    delete, re-define, re-calibrate
    Originally posted by rbnew View Post
    Hi everyone,
    Once you've gone through the setup, as you've done, you need to re-define all probes and tool(s), and the re-calibrate. DCC calibration should work fine, you don't need to do it manually.
    If you don't delete and re-define the probes, they retain the memory of their original orientations.
      thank you I was using old tools.
      B&S Oryzo
      PH10 TP20
      3.7MR3
      • DmisDave
        Changing probe in a program?
        by DmisDave
        I have a TP200 and two modules with different probes attached. I would like to change probes in the program. It appears that I can use a Load Probe command...
        05-14-2010, 12:29 PM
      • Ken8282
        Probe Calibration
        by Ken8282
        I came in after the weekend and went to calibrate the probe and it kept contacting the sphere and flexing the probe to much so I got an unexpected probe...
        11-05-2018, 02:26 PM
      • tnguyen
        Probe calibration need help
        by tnguyen
        Hi.
        It had something changes calibration by Operator yesterday. Today, I calibrate Master Probe A0B0, It's runing fine, then calibrate all probes,...
        05-08-2011, 04:50 PM
      • Stoneman
        Probe Orientation
        by Stoneman
        I'm a newbie to PC-DMS and forums so here goes...
        I import a CAD file. How do I change the probe orientation. Now the probe looks upside down......
        09-01-2010, 05:48 PM
      • PixleyRichards
        Probe Changing
        by PixleyRichards
        Unlike most of you, I'm fortunate enough to get to change my probes manually. But sadly, this creates deviation in the measurements. I know that I could...
        06-21-2006, 01:26 PM
