How do I go about using instead of 0-360degrees I would like to use 0-180degrees to match the CNC machine but it seems like when I put a -value for nominal the actual is positive and the vise versa, Feels like I'm chasing my tail.....There's got to be a simple solution for this.......
Degrees
F5, Dimensions Tab, lower right corner allows you to select angles - 0 to 360 or 0 +/-180
Is that what you are looking for?
Otherwise you will need to be more descriptive of what is not working.
Change the angle from (TRUE) to (COMPLEMENT) to get the complementary angle...
DIM 1_146= 2D ANGLE (TRUE) FROM LINE 46_1 TO ZAXIS ,$
A 135.000 1.000 1.000 134.934 -0.066 0.000 ----#----
DIM 1_146= 2D ANGLE (COMPLEMENT) FROM LINE 46_1 TO ZAXIS ,$
A 45.000 1.000 1.000 45.066 0.066 0.000 ----#----sigpic
PCDMIS 2012
Windows Office XP
Very sorry guys, did not explain myself to good I was talking about a bolthole pattern of 6 circlres with one in the center, created the rotation from the center hole to the 3 Oclock hole so when I called out the 3 Oclock hole in polar the PR is 2" and PA is 0 but when I callout the 9 Oclock hole the PR is 2" and the PA is 180 So far no probem I could use the 360 degree default under
f5 but then it would not match the CNC. So when using the 0-180 default that's when the problem starts. So now when I call out the 9 Oclock hole with the nominal 180 the 1st time I ran it, it came out fine +179.9976 but the 2nd time I ran it the measured -179.9987 so now I'm 180 degrees off. So then I changed the nominal to -180 now the parts positive. (HMMMMMMMMM) Called tech support and they said that in 3.7mr2 that was a problem so they told to download 3.7mr3 which had the fix. So I will let you all know...... Also since I live in a rural area in Georgia and just now getting DSL I bought a compter and now have one at home...Maybe that a scary thought.....sigpic
You are talking about .0037º difference. I dont see the problem. The hole is showing up above centerline one time and below centerline the other time. You need to use 0 to 360 if it bothers you that much.
Originally posted by cmmguy View PostYou are talking about .0037º difference. I dont see the problem. The hole is showing up above centerline one time and below centerline the other time. You need to use 0 to 360 if it bothers you that much.Last edited by AuRules; 02-28-2007, 07:41 AM.sigpic
OK, I think that I am following you, but if dont want 0 to 360º(because you dont want a number over 180º), and you dont want 0º +/-180º because it gives you a negative number(your operators cant use a negative angle), can you explain "more-better" how you would like the results to look for the various possible scenarios. ie you say that you can only go 0-180 on the machine - how do you want that displayed for an angle that is 182º (or -178º).
It sounds like you are looking for a non-standard depiction of an angle reading, this will require either a script or logic in the part program to create the depiction that you want.
What I think he is saying is that the same angle, 180, reports sometimes as -180 and sometimes as +180, for the same feature measured. Then, sometimes you will get 180.012 and the next time you get -179.988, all depending on 'which direction' Pcdmis goes from the 0, clockwise or counter-clockwise, to get to the angle.sigpic
When you do an angle between feature in 2010 MR2, the three place decimal result you get, would that be in degrees or microns? I have a boss that would...
06-05-2012, 05:00 PM -
by HAREKhello
How do I cycle in pcdmis degrees radians.
but not vb code. can be assignment..
example : 85.75° = 85° 45'-
Channel: PC-DMIS Code Samples
11-06-2013, 09:25 AM -
by 57shrimpwhere do I change angles from decimal to degrees m s
12-07-2016, 01:51 PM -
by grandpaal56I am currently running v4.2 MR1. I am reporting the angle of some lines around a circle. I am using constructed 2D lines from the center of the circle...
07-23-2014, 10:51 AM -
by andrewb91Hello all, we're a build to print shop and some of our prints show angle tolerances as degree, minutes, seconds and others as decimal, is there an easy...
02-09-2018, 12:43 PM -
