I would like to export measured x,y,z, check results only to excell and export as a csv file from excell
Measured x,y,z, to excell only
PM with e-mail and I'll send it to you. I have 2 versions for PCD V4.0 and up. One of them brings the measurements into Excel in Row format the other one brings them into column format.
HTH,
t.Global Image 555
PH10M-TP200
PC-DMIS Cad ++
Win7 64 bit
V2014.1
Since you are using 3.5 and 3.7 the spreadsheets I have will not work. You will need the one from the Wilcox site. Look in the custom script repository for pcdmistoexcel_auto.zip. You will have to reference the appropriate library for the version of PCD that you are running as described on the Wilcox website.
HTH,
t.Global Image 555
PH10M-TP200
PC-DMIS Cad ++
Win7 64 bit
V2014.1
by BlueRayI'm running PcDmis 2016 sp9... I can get it to export an excel file in a csv format, but none of the values from the points I took show up in the file....
10-05-2017, 11:23 AM -
by TestedDoes anyone know of a way I can send ( assignment data directly to a excel file )
05-22-2006, 08:42 AM -
by adamclinardIs there a way to export data reports from dmis straight to an excel file?
11-21-2007, 01:53 PM -
by jkb_mcgCould anyone tell me how to export data values so they someone else could open them and plot them into an excel spreadsheet?
10-17-2006, 12:16 PM -
by Slug DawsonHello all,
We run Excel 2007 on our cmm computer. It has compatiability mode to allow the software to open up previous version of Excel spreadsheets...-
09-28-2010, 06:12 PM -
