Probe error help please
  • Probe error help please
    I had a probe error start this morning that I can't figure out. I'm running v. 3.5 on a manual micro excel machine. This is what the error looks like.
    T1A0B0 ERROR X 0.0000 Y 0.0000 Z 0.0000 D=5285.5025 SD= 0.000 PR 0.0000
    Max X 0.0000 Y= 0.0000 z= 0.0000 PR=0.0000
    Min X 0.0000 Y= 0.0000 z= 0.0000
    NUMBER MEASURED=1
    SP1 CENT X 6.6841 Y 20.6364 Z-6484.7962.7962 D0.7500
    Measured probe diameter error exceeds the limits.
    Not that I figured anything out but your machine is expecting a probe diameter of .75 inch and it got 5285.5025 inch. Did you notice that?
    TK
    sigpicHave a homebrew
      Make sure your probe is built correctly
      Try restarting your machine
      Delate probe file & start again.
      3 suggestions
        Have you tried deleting the tool and re-creating it? Same with the probe file, but I would try the tool, first.
          I can confirm that deleting the probe files (including the results) and re-calibrating will fix this issue. I've had it before but I can't figure out why it does this.
