When dimensioning the distance between a line and a circle I am getting 2 different answers. If I do line to circle it is 6.2 mm longer than if I do circle to line. When I first programmed it I did line to circle and the dimension was out of tolerance so I went to engineering thinking I had a bad cad file. They checked out the cad file and said it was good so I started playing around with my program, trying different things when I came across this situation. Why would it matter what feature I choose first if everything else is the same??? Has anyone else seen this before?
distance between a line and circle
When you do LINE to CIRCLE, it uses the CENTER point of the line to the center point of the circle, when you do CIRCLE to LINE, it does the shortest distance, circle, perp to line, not to line center.sigpic
I tried several things. I rotated to the line and set the 0,0 in the circle, and still get 2 different answers. I did a distance between the 2 and also did location of line. Location was good and so was distance if I did circle first.
My opinion is they should calculate them the same no matter what order you use.
Originally posted by Carolyn McKean View PostI tried several things. I rotated to the line and set the 0,0 in the circle, and still get 2 different answers. I did a distance between the 2 and also did location of line. Location was good and so was distance if I did circle first.
My opinion is they should calculate them the same no matter what order you use.sigpic
Originally posted by Carolyn McKean View PostWhen dimensioning the distance between a line and a circle I am getting 2 different answers. If I do line to circle it is 6.2 mm longer than if I do circle to line. When I first programmed it I did line to circle and the dimension was out of tolerance so I went to engineering thinking I had a bad cad file. They checked out the cad file and said it was good so I started playing around with my program, trying different things when I came across this situation. Why would it matter what feature I choose first if everything else is the same??? Has anyone else seen this before?
Good day!!sigpicIt's corona time!
Originally posted by AuRules View PostIs this example what you talking about Matt. Since I sitting hear waiting on the operators to fire the machine up and give me some work.sigpic
Originally posted by RussL View PostCatia does similar things with measure.
I believe the software should be written to re-evaluate the first element once the second element is chosen so you get the same answer regardless of order.
Exactly. Otherwise is stupid.
by jcos81This is a little more confusing than it sounds. I am trying to get an intersection point between features lin18 and cir 13.
However I need...-
05-10-2016, 03:47 PM -
by schmidthI'm trying to find the intersection point between a line (circled in red) and a circle (labeled CIR_REAR). The point that is given from the intersection...
09-26-2016, 10:28 AM -
by DarrollhI need to construct a line from the center of a circle to its tangent. I forgot how I did this before. I know its simple. Thank you in advance.
05-11-2019, 11:58 PM -
I am trying to create an intersection point using a line and a circle. (line 2 & circle 2 I am using the method below. The point is not even close...
06-26-2017, 06:14 PM -
by MansukhCan I construct a parrellel line from a feature like circle or point to X, Y or Z axis?
04-12-2010, 09:51 AM -
