Scan Measured to Nominal
  • Scan Measured to Nominal
    Howdy everyone, I'm trying to get my scans to register the measured values and use them as nominals for future scans. But all the points don't seem to be changing. Any ideas?
     MOVE/CLEARPLANE
    SCN2       =FEAT/SCAN,LINEAROPEN,NUMBER OF HITS=20
                ,SHOW HITS=YES,SHOWALLPARAMS=YES
                EXEC MODE=NORMAL, NOMS MODE=MASTER,CLEARPLANE=YES,SINGLE POINT=NO,THICKNESS=0
                FINDNOMS=0.0787,SELECTEDONLY=NO,USEBESTFIT=NO,PROBECOMP=YES,AVOIDANCE MOVE=NO,DISTANCE=0,CAD Compensation=NO
                DIR1=LINE,INCR=0.05
                HITTYPE=VECTOR
                INITVEC=-0.9912974,0.1306494,-0.0161314
                DIRVEC=0.3865012,-0.9222861,-0.0022779
                CUTVEC=-0.0175654,-0.0098305,0.9997974
                ENDVEC=0.2575499,-0.9662522,-0.0049758
                PLANEVEC=-0.9661053,-0.2574103,-0.0195044
                POINT1=-3.0858,-2.0981,0.0042
                POINT2=-2.1166,-2.4043,0.0002
                MEAS/SCAN
                BASICSCAN/LINE,NUMBER OF HITS=20,SHOW HITS=YES,SHOWALLPARAMS=YES
                <-3.0858,-2.0981,0.0042>,<-2.1166,-2.4043,0.0002>,CutVec=-0.0175654,-0.0098305,0.9997974,DirVec=-0.1304643,-0.9913799,-0.0120422
                InitVec=-0.9912974,0.1306494,-0.0161314,EndVec=0.242315,-0.9700395,-0.0175176,THICKNESS=0
                FILTER/DISTANCE,0.05
                EXEC MODE=NORMAL
                BOUNDARY/PLANE,<-2.1166,-2.4043,0.0002>,PlaneVec=-0.9661053,-0.2574103,-0.0195044,Crossings=1
                HITTYPE/VECTOR
                NOMS MODE=MASTER
                HIT/VECTOR,<-3.0858,-2.0981,0.0042>,<-0.9912974,0.1306494,-0.0161314>,<-3.0154,-2.1074,0.0054>,T=-0.071
                HIT/VECTOR,<-3.0923,-2.1477,0.0036>,<-0.9912974,0.1306494,-0.0161314>,<-3.0312,-2.1559,0.0045>,T=-0.0617
                HIT/VECTOR,<-3.0989,-2.1972,0.003>,<-0.9912974,0.1306494,-0.0161314>,<-3.0465,-2.2041,0.0037>,T=-0.0528
                HIT/VECTOR,<-3.1054,-2.2468,0.0024>,<-0.9912974,0.1306494,-0.0161314>,<-3.0578,-2.2531,0.003>,T=-0.048
                HIT/VECTOR,<-3.1107,-2.2965,0.0018>,<-0.998446,0.0533522,-0.0161004>,<-3.0621,-2.2991,0.0025>,T=-0.0487
                HIT/VECTOR,<-3.1103,-2.3465,0.0013>,<-0.9973401,-0.0710952,-0.0160677>,<-3.0569,-2.3429,0.0021>,T=-0.0535
                HIT/VECTOR,<-3.1036,-2.3961,0.001>,<-0.980788,-0.1944146,-0.0160565>,<-3.0507,-2.3857,0.0019>,T=-0.0539
                HIT/VECTOR,<-3.0908,-2.4446,0.0007>,<-0.9489454,-0.3150309,-0.016067>,<-3.0444,-2.4293,0.0016>,T=-0.0488
                HIT/VECTOR,<-3.0721,-2.491,0.0006>,<-0.9025095,-0.4303689,-0.0160989>,<-3.0332,-2.4725,0.0013>,T=-0.0431
                HIT/VECTOR,<-3.0477,-2.5348,0.0006>,<-0.8418512,-0.539468,-0.0161519>,<-3.0139,-2.5132,0.0012>,T=-0.0402
                HIT/VECTOR,<-3.0182,-2.5751,0.0007>,<-0.7683454,-0.6398297,-0.016225>,<-2.9894,-2.5511,0.0012>,T=-0.0375
                HIT/VECTOR,<-2.9839,-2.6115,0.0009>,<-0.6829701,-0.730264,-0.016317>,<-2.9613,-2.5874,0.0014>,T=-0.033
                HIT/VECTOR,<-2.9452,-2.6434,0.0013>,<-0.5867599,-0.8095944,-0.0164269>,<-2.9284,-2.6203,0.0017>,T=-0.0286
                HIT/VECTOR,<-2.903,-2.6702,0.0018>,<-0.4816347,-0.8762158,-0.0165525>,<-2.8908,-2.648,0.0021>,T=-0.0253
                HIT/VECTOR,<-2.8577,-2.6915,0.0024>,<-0.3691254,-0.9292297,-0.0166919>,<-2.8504,-2.673,0.0026>,T=-0.0199
                HIT/VECTOR,<-2.8101,-2.7071,0.0031>,<-0.2505613,-0.9679542,-0.0168436>,<-2.8064,-2.693,0.0032>,T=-0.0145
                HIT/VECTOR,<-2.761,-2.7166,0.0038>,<-0.1284895,-0.9915651,-0.0170042>,<-2.7598,-2.7072,0.0039>,T=-0.0094
                HIT/VECTOR,<-2.7111,-2.7199,0.0047>,<-0.0043327,-0.9998432,-0.0171718>,<-2.7111,-2.7166,0.0046>,T=-0.0034
                HIT/VECTOR,<-2.6611,-2.717,0.0056>,<0.1201196,-0.9926079,-0.0173442>,<-2.6606,-2.7202,0.0054>,T=0.0032
                HIT/VECTOR,<-2.6119,-2.708,0.0065>,<0.242315,-0.9700395,-0.0175176>,<-2.6098,-2.7165,0.0063>,T=0.0088
                ENDSCAN
                ENDMEAS/
                MOVE/CLEARPLANE
    You are using MASTER. Doesn't it set the values it 1st measures and sets them as the nominal and compares everything back to the "master". So your measured and the nominal would be the same ? I would like a 2nd opinion for sure on this. I scan everything from CAD so I would never use MASTER, only FIND NOM. What are you trying to do ? Tell us a little more of your process.
      I'm not at the cmm, but I think you could use "relearn" mode.
        I am working on a reverse engineered part, that was started before I started working for my current employer. The first one was measured and rejected due to it not matching up to the original. A CAD model was made which I used to write the program, then measured the OEM. The problem is that the measured data from the OEM data is not overwriting the theos produced by the CAD even tho I have MASTER selected. And I cant figure out why.
          I tried the relearn mod but it wasn't working, at least not while I had the CAD model imported. Once i removed the CAD model it seems to be working.
            If you ARE using a CAD settings should be DEFINED and FINDNOMS . Make sure probe comp and CAD comp are on.
            If you ARE NOT using a CAD the settings should be RELEARN and MASTER. Make sure probe comp is on.
            Jesse Krook
              Consider F5 - Find Nominals During Exercution. (with a properly set point target radius)
              Don't forget to turn it off after the program runs. As always, use this powerful feature on a copy of the program.
