measuring diameters on Diameter
  • measuring diameters on Diameter
    Hello,
    I am needing help trying to figure out how to measure .406 holes on a 3.562 diameter. I can measure one hole if I have it set to an axis but the other 2 holes are at aprox 60° ± and I cant figure it out.
    I'm using PC-DMIS CAD ++ 4.0
    You have to use one of the .406 dia holes in your alignment. That will set the other 2 by whatever the angle is and you should be able to rotate your probe & angle & measure diameters.
      I did an alignment using a .406 hole. When I go to measure another hole which is 120° over it asks me change plane X Plus ?... The hole isn't on a plane. and after it measures the hole it shows up in the display like a line going thru the od and id.
        Is there a company that does in house training on PC DMIS?
          Where are you located? There are many options.
            Muskogee OK
