variables
  • variables
    Looking for a way to get pc-dmis to take an operator entered part # & replace PART NAME : with entered data using variables.....
    Many thanks.....
    trice
    4.3 mr1
    Can't be done, that is a 'set' variable in the Pcdmis code itself, if you are refering to the header info (pre V4).
      I think this answers what you want to do if I underatand your question.
        Easy enough with a script:
        Sub SetPartName()
        'Set up communication With PC-DMIS
        Dim pcdApp As Object
        Set pcdApp = CreateObject("PCDLRN.Application")
        Dim pcdPart As Object
        Set pcdPart = pcdApp.ActivePartProgram
        Dim pcdCmds As Object
        Set pcdCmds = pcdPart.Commands
        Dim pcdCmd As Object
        'Declarations
        Dim strValue As String
        strValue = "123456"
        pcdPart.PartName = strValue
        End Sub
        Only you will just need to pull the operator entered number into the script instead of a constant.
          Wouldn't be easier to just make a copy of the program? So each part number has its own .prg/database.
          sigpicIt's corona time!
            Than you
            Problem solved, tech support sent me a script to do what I was needing....
            Thanks for the replies.
            trice
            4.3 mr1
              Could you please post the script (zipped)? Thank you
                James;
                Here you go
                trice
                4.3 mr1
                  Thanks!!
                  I don't know if I'll use it ant time soon, but it is always better to have than try to get later.
