Starting yesterday at around 2:30pm PC-Dmis will not print a report unless I go into the last execution report mode and use F4. This is happening in all our part programs.
The program reaches the print command at the bottom:
C2 =COMMENT/YESNO,NO,
, Would you like a print-out?
IF/C2.INPUT=="YES"
PRINT/REPORT,EXEC MODE=END,$
TO_FILE=ON,AUTO=13,$
TO_PRINTER=ON,DRAFTMODE=OFF,$
END_IF/
IF/C2.INPUT=="NO"
TO_FILE=ON,AUTO=8,$
TO_PRINTER=OFF,DRAFTMODE=OFF,$
END_IF/
When it asks, "would you like a print out?" and I click "Yes" I get an error message PCDLRN that says, "Could not start print job."
When I check my print options everything is still set correctly. Nothing has changed from where it was set yesterday - or every day for the last 2 years.
I recently copied all the .prg's into a folder on the local drive after everyone's suggestions last week. The settings still output a .pdf to the part folder on one of our network drives, but this didn't interfere with anything in the last few days - so I can't see it making a difference.
Again, if I view report mode and hit F4 then it prints with no problem - which also tells me the settings are still correct.
Anybody have any idea what might be going on here?
IF/C2.INPUT=="YES"
END_IF/
IF/C2.INPUT=="NO"
TO_FILE=ON,AUTO=8,$
END_IF/
