I noticed that every feature i measure at 30ยบ indicates .001" minimum out of round on the CMM. I double check with manual gauging and find it to actually be tenths. I run 3.7 MR3 with no CAD files on a RS-670 with PH10MQ and TP200b. I have also had this same issue using a TP200 and any of 6 modules i have on hand reguardless of stylus size. Anyone else see an issue like this or have any suggestions as to what i can do?
Roundness issue
3D feature or 2D? The reason I ask is if you are not in a level scenario that sets you up well to measure normal to a 2D feature then your vector error may show as a roundness problem. First susspicion should be things like part and styli cleanliness. Also what type of manual gage are you using 2 point or 3 point contact and what kind of process is generating that feature and how many hits are you taking? ? Lastly a CMM is not the best for roundenss but I think it is possible to be more effective than what you are getting if you take all these things into account and prepare for them.<internet bumper sticker goes here>
Here are the last 4 points of a 36 point pattern at 30ยบ probe angle. Also should be noted that i use a 100mm extention and TP200b with standard force module and 2BY30MM stylus in this program. The Datums were set in DCC as well.
MOVE/POINT,NORMAL,6.0324,-3.4189,5.4531
TIP/T1A30B-90, SHANKIJK=0.5, 0, 0.866, ANGLE=-90.0005
PNT105 =FEAT/POINT,RECT
THEO/2.5247,-2.1185,5.4531,0.7660442,-0.6427879,0
ACTL/2.5248,-2.1095,5.4533,0.7660442,-0.6427879,0
MEAS/POINT,1
HIT/BASIC,NORMAL,2.5247,-2.1185,5.4531,0.7660442,-0.6427879,0,2.5248,-2.1095,5.4533,USE THEO = YES
ENDMEAS/
PNT106 =FEAT/POINT,RECT
THEO/2.8543,-1.6479,5.4531,0.8660252,-0.5000004,0
ACTL/2.8532,-1.6409,5.4534,0.8660252,-0.5000004,0
MEAS/POINT,1
HIT/BASIC,NORMAL,2.8543,-1.6479,5.4531,0.8660252,-0.5000004,0,2.8532,-1.6409,5.4534,USE THEO = YES
ENDMEAS/
PNT107 =FEAT/POINT,RECT
THEO/3.0971,-1.1272,5.4531,0.9396925,-0.3420205,0
ACTL/3.0955,-1.1229,5.4536,0.9396925,-0.3420205,0
MEAS/POINT,1
HIT/BASIC,NORMAL,3.0971,-1.1272,5.4531,0.9396925,-0.3420205,0,3.0955,-1.1229,5.4536,USE THEO = YES
ENDMEAS/
PNT108 =FEAT/POINT,RECT
THEO/3.2457,-0.5723,5.4531,0.9848077,-0.1736486,0
ACTL/3.2447,-0.5703,5.4534,0.9848077,-0.1736486,0
MEAS/POINT,1
HIT/BASIC,NORMAL,3.2457,-0.5723,5.4531,0.9848077,-0.1736486,0,3.2447,-0.5703,5.4534,USE THEO = YES
ENDMEAS/
DIA -8- =FEAT/CIRCLE,RECT,OUT,LEAST_SQR
THEO/0,0,5.4531,0,0,1,6.5918
ACTL/0,0.0092,5.4529,0,0,1,6.592
CONSTR/CIRCLE,BFRE,PNT73,PNT74,PNT75,PNT76,PNT77,PNT78,PN T79,PNT80,PNT81,PNT82,PNT83,PNT84,PNT85,PNT86,PNT8 7,PNT88,PNT89,PNT90,PNT91,PNT92,PNT93,PNT94,PNT95, PNT96,PNT97,PNT98,PNT99,PNT100,PNT101,PNT102,PNT10 3,PNT104,PNT105,PNT106,PNT107,PNT108,$
PNT108,,
OUTLIER_REMOVAL/OFF,3
FILTER/OFF,UPR=0
DIM DIAMETER -8- MIN. 6.5913)= LOCATION OF CIRCLE DIA -8- UNITS=IN ,$
GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
D 6.5920 6.5918 0.0000 0.0000 0.0002 0.0002 -------->
RN 0.0011 0.0000 0.0000 0.0000 0.0011 0.0011 -------->
END OF DIMENSION DIAMETER -8- MIN. 6.5913)
DIM DIAMETER -8- (REPAIR -07)= LOCATION OF CIRCLE DIA -8- UNITS=IN ,$
D 6.5920 6.5918 0.0005 0.0005 0.0002 0.0000 ------#--
END OF DIMENSION DIAMETER -8- (REPAIR -07)
Is the probe pointing straight into the hole? If not, the probe compensation maybe off, due to the probe hitting above its equator. Also, the CMM is not necessarily the best way to check roundness, especially if it is tight tolerance. There have been numerous discussions here about this very subject.When in doubt, post code. A second set of eyes might see something you missed.
I definetly understand what your saying and you may be right on. What i have been doing is measuring at an angle that is not perpendicular to the surface of measure. _|_ / <---- basically like this with the / being the probe. I am forced to do this due to constraints of the CMM and the size and shape of the part. We do have a 2nd CMM with a TP20 and no 100mm extention that does not have the same roundness issue measuring the same way. My guess is the less sensitive probe and no extention help it to remain consistant.
by BrandnewHi all,
So i looked about the threads and did find some with similar questions but it didn't seem to resolve my question. So i thought...-
07-16-2013, 05:45 PM -
by gopherI have a part with 24 equally spaced slots around an outer diameter. I could have used a pattern for this example, but I have other situations where...
09-05-2007, 07:48 PM -
by Crazy Man!Hello, I'm new here.
A little about myself so you know where I'm coming from:
I have an associate degree in Mechanical Drafting...-
04-18-2012, 03:40 PM -
by jrykrlHere's my program
PART NAME : practice dcc
REV NUMBER :
SER NUMBER :
STATS COUNT : 1
STARTUP =ALIGNMENT/START,RECALL:,...-
03-29-2010, 02:29 PM -
by Brandnewi'm just wondering if someone can explain to me why this is the case. i'm not using any alignments other than an origin point for the part. The first...
12-10-2014, 01:10 PM -
