assigning varialbes
  • assigning varialbes
    I'm running version 3.207 Beta trying to dimension the True Position callout on Datum -C-, balloon 108 in the lower view.
    Datums -A- and -F- are shown in the upper view. Datum -D- is a hole pierced in Datum -H- at balloon 16 BASIC 31.72.
    I'm trying to create a generic circle using the measured value of balloon 18 for the diameter by assigning a variable.
    How do I assign the variable?
    Does someone see a better way?
    Thanks
    Perry
    B&S Mistral
    3.207 Beta on XP
    Older'n dirt
    Do you have all features measured? If so, I will construct an alignment (ABF) and recall True position with ballons 105 [31.7] and 109 [13.95].
    sigpicIt's corona time!
      You can assign it by declaring the variable to equal your feature name for balloon 18 (I'm going to call BALLOON18) then the extension .D. so it would lok something like so:
                  ASSIGN/V1 = BALLOON18.D
      The same syntax BALLOON18.D can be used in the generic feature in lieu of the variable name. So concievably you could skip the assignment.
        DIM 018 = 2D DISTANCE FROM LINE L_DAT_AH TO LINE L_DAT_AB PARALLEL TO   XAXIS, NO_RADIUS  UNITS=MM ,$
        GRAPH=OFF  TEXT=OFF  MULT=10.00  OUTPUT=BOTH
        AX  NOMINAL    MEAS     +TOL     -TOL      DEV    OUTTOL
        M    53.900   53.867    0.200   -0.200   -0.033    0.000 ---#-----
        I'm trying to crete a generic circle using the measured value of DIM 018 as the diameter.
        If I'm completely off track trying to use the bonus on Datum -F- say so.
        Perry
        B&S Mistral
        3.207 Beta on XP
        Older'n dirt
                      ASSIGN/V1 = 018.M.MEAS
          Except with V3.207 you can't get a reference to features or dimensions whose names start with numbers. You'll need to tack a letter in front of it.
          DIM D018 = 2D DISTANCE FROM LINE L_DAT_AH TO LINE L_DAT_AB PARALLEL TO   XAXIS, NO_RADIUS  UNITS=MM ,$
                      ASSIGN/V1 = D018.M.MEAS
            And, you can always type in ASSIGN/V1 then hit F9 and it will pull up a helpful little screen that will walk you through any possible thing you can assign to a variable.
              Yes, the F9 dialog will give you a lot of hints as to the things you can do. I forget to mention that.
                Success!!
                Craig...THAT was it. I did not know I needed a letter at the front af the DIM name. I use variable references to features all the time but I have never been able to get them to work referencing dimensions. If that is in the help files I missed it.
                Thanks to you too, Matt. I use F9 almost as much as CRTL S.
                Thanks all for your input. That's why ya'll are the MASTERS and I'm just a lowly peasant.
                Perry
                B&S Mistral
                3.207 Beta on XP
                Older'n dirt
                  Well, I think 'peasant' is too derogatory, how about serf instead?
                    You're the MASTER, name me.
                    Craig, leave that one alone.
                    Perry
                    B&S Mistral
                    3.207 Beta on XP
                    Older'n dirt
                      I don't think it is in the help file, I learned that one the hard way.
                      Don't sell yourself short, I get a lot out of all of you.
                        yeah, lots of things missing from the help files. Like, DON'T use math operations in the feature OR dimension ID's. Ya kind of have to look at them like old BASIC programming. If it is all numbers, it will see it as a number, not a label, thus the need for a letter in the DIM ID for the assignment to work, otherwise it thinks you are entering a number, 123.whatever, then looses it's mind when it see something other than move numbers after the decimal point, probably the same with feature ID's, but I don't think anyone uses just numbers for feature ID's.
                          3.7 works well on this issue, no need to prefix your IDs with a letter, although I'd caution against using only numbers in your ID. There should be an underscore or a letter or something inocuous in the ID. However with 3.2 you can not start with a number even if at some point in the ID you have letters.
                          3.2:
                          D1_125 works
                          1_125 does not work
                          3.7:
                          D1_125 works
                          1_125 works also
                          have not tried 1125, don't want to.
                          I can't speak for 3.5, never used it.
                            I can't beleive he let that one slide
                            TK
                            sigpicHave a homebrew
                              Freakin variable question again
                              I got the previous one worked out thanks to the gurus. Now I have another variable question.
                              I'm using a Comment/Input command to enter a hole ID being checked with a pin gage:
                              COM_DATB =COMMENT/INPUT,PIN GAGE DAT -B- HOLE
                              ASSIGN/V1 = COM_DATB.INPUT
                              Later in my program I'm trying to use V1 as the DIAMETER for a generic circle:
                              DAT_B =GENERIC/CIRCLE,DEPENDENT,RECT,OUT,$
                              NOM/XYZ,0,0,0,$
                              MEAS/XYZ,C22.X,C22.Y,C22.Z,$
                              NOM/IJK,0,0,1,$
                              MEAS/IJK,C22.I,C22.J,C22.K,$
                              DIAMETER/10.2,V1
                              For some reason, probably me, the V1 value is not being picked up:
                              DIM 22= LOCATION OF CIRCLE DAT_B UNITS=MM ,$
                              GRAPH=OFF TEXT=OFF MULT=1.00 OUTPUT=BOTH
                              D 10.200 1.000 0.100 -0.100 -9.200 9.100 <--------
                              END OF DIMENSION 22
                              What have I hammered up this time?
                              I'm doing this to allow PC-DMIS to locate the hole for True Position but use the pin gage check for the diameter so both are on my PC-DMIS report.
                              TIA for everyone's help.
                              Perry
                              B&S Mistral
                              3.207 Beta on XP
                              Older'n dirt
