Does anyone knw if there is a way to manually move sample hits around a slot on version 3.7 MR3? I know you can select a sample hit on the cad, right click it and it will give you the options of adding deleteing or user defined hits, but I can't figuire out how to use this option. Any help would be appreciated. Thank you !
Move Sample Hits
I had asked this question a short time ago with no luck.
Yes, you are supposed to be able to "drag" the sample hits.
The trouble is on my machine, a B&S mistral 07/07/05, using v3.7mr3, I could drag the hits but they would not stay there. Why???????????
When the "sma" folks did it, they were able to retain the new locations.
I too would appreciate help on this one.
ZydecoPetesigpic
I've been able to move the points individually, but if I go back and edit the feature after running it I get the PCDLRN error. Tech support was no help, they just said it must be the CAD file, even though they could duplicate the problem. Money well spent.
JaimesigpicYou're just jealous the voices talk to me.
OK. Thanks Winston. I got the hole to work useing the sheets Winston attached. But the slots will not budge. I have emailed B & S and I am waiting for a response. I will let anyone that is interested know whatever I find out. Thanks again!sigpic
Yes, I drag the sample hits around all the time. It works really well. a few tips:
1) grab the leader before the hit to move.
2) center the view using the icons in the menu box
3) use the proper work plane
all these and practice help to make 3.7 mr3 a very effective tool.
-Gabrielsigpic
by RascalIm looking for some help with sample hits. i have an inlet plate with a Slot i want to have 3 sample hits and a 6 point slot. i kick DCC mode on Toggle...
11-19-2012, 03:17 PM -
Today, I am quite frustrated. Running 3.7mr3.
Measuring a hole in plastic, with cad. If I want to use 3 initial &...-
03-30-2006, 11:12 AM -
by JR VILLAim having a problem moving my hits in the graphics view when I chose a hole the sample hits are there but I cant manipulate them if I change them in...
10-02-2013, 03:00 PM -
by dwadeCan I pull sample hits from an autocircle? I've looked and looked and cannot find out how to do it. I can pull the individual hits from the cirlces but...
12-19-2007, 11:38 AM -
by keegoI'm trying to use sample hits on an autocircle but am having problems. I have my z for the circ at -5 and my spacer set to 4. It takes the sample hits...
10-16-2009, 08:34 AM -
