Looking for some help with the 1.839/1.849 distance. This callout is not a Cartesian distance . Its asking for the circumference value from point to point. I'm thinking this is going to need some combination of variables. Using 2015.1 CAD. Thanks!
Distance with circumference
Originally posted by kingsld1 View PostJust to be difficult.....
What if the diameter is significantly out of round?
ASSIGN/V1=SCN1.HIT[1..(SCN1.NUMHITS-1)].XYZ
ASSIGN/V2=SCN1.HIT[2..SCN1.NUMHITS].XYZ
ASSIGN/V3=SUM(SQRT(DOT(V2-V1,V2-V1)))
ASSIGN/V4=SQRT(DOT(SCN1.HIT[SCN1.NUMHITS].XYZ-SCN1.HIT[1].XYZ,SCN1.HIT[SCN1.NUMHITS].XYZ-SCN1.HIT[1].XYZ))
ASSIGN/LENGTH=V3+V4
The uncertainty on this method should be approximately half of the density of the scan.
For an open scan, keep only V3...
- Likes 1
There is the feature type CURVE available under constructions, which has a length that can be dimensioned. With measuring points close enough it might give a good approximation.AndersI
- Likes 2
You can download the core manual, chap.26... Print it, read it, and try to find some memories of maths or trig...
Assignments is only a tool box, but a very nice tool box !
ftp://ftp.wilcoxassoc.com/docs/v2016.0manual/ (I'm unable to add the link with "add link" button...)
But it seems to work "alone" !
Does anyone know how to write a formula to the distance between 2 points and divide by2.
Kenn
"The need of the many...-
04-08-2006, 01:33 PM -
by lucianoI usinng Pc DMIS 4.3 MR1 and I have a question mark about 3d distance .Something is strange for me..must calculate the 3D distance of two circles , I...
03-15-2013, 04:26 AM -
by ClementineWe have older version of PCDMIS on this ARM. I need some help recalling programing perpendicularity.
When programing perpendicularity,...-
Channel: PC-DMIS Portable
12-12-2012, 11:54 AM -
by cmmcaliguyI have to circles,different diameters,same "z","y" axis. I'm trying to get the distance between the bottom of each diameters radius...
05-10-2006, 02:07 PM -
by J. LuskOk, perhaps I can get the basics on a distance....
Simple: I've got two internal cylinders that intersect, making a cross. One is along...-
08-01-2008, 04:04 PM -
