Analog Scanning
  • Analog Scanning
    How can I create a point where an open scan (high density) with a 3 axis vertor crosses a constructed plane. I can turn the scan into a line and the pierce a line with a plane. But for accuracy I'm wanting to create this point with actual data. Infact the point would actually be created from a line generated between the 1st point before and the 1st point after the desired cross plane. I ask this because I have hundreds of 3D scans which I want to cross section at different levels.
    As you can read I'm trying to digitize a part with-out the right equipment. I've had great success at doing this but I'm having to do must of the work in 3D software which is very time consuming.
    Thanks in advance.
