Running version 4.1, Does PCDMIS perform Datum Shifting accurately? Detailed answer from tech support would be greatly appreciated.
Datum Shifting
Originally posted by BRSMR View PostRunning version 4.1, Does PCDMIS perform Datum Shifting accurately? Detailed answer from tech support would be greatly appreciated.
Originally posted by cmmguy View PostThat might require a phone call. Wes, you got that number handy??
Originally posted by BRSMR View PostRunning version 4.1, Does PCDMIS perform Datum Shifting accurately? Detailed answer from tech support would be greatly appreciated.sigpic
Yeah, well I do have the phone number but. . . A couple of years ago when I moved up to 3.7MR2 and was having some obnoxious problems with true position I was put in touch with a fellow who is supposed to be the B&S GD&T expert. I tried to get an answer to the very question you are asking. I was told that the math pc-dmis uses comes from the ASME Y14.5.1M-1994 - Mathematical Definition of Dimensioning and Tolerancing Principles. I have a copy of that book and the math gets quite hairy. As I have demonstrated several times, I still have a long way to go mastering the basic standard before I dare tackle this one. HTHsigpic"Hated by Many, Loved by Few" _ A.B. - Stone brewery
BRSMR,
Just to make sure I understand what you are asking, are you doing shift pattern of holes? Shifting your entire pattern around? I used to do this in excel a lot years ago. I transferr all my data to excel and moved the entire pattern at once to see if it would work. I never could get the software to work correctly but that was many versions back. If you need any help PM me.Dale
v2011 MR1 CAD ++
Can you give us your exact example and please tell us why you think it does not properly shift.
I think it does. I tried some known data sets and it did it correctly. But I must admit that sometimes datashifts can be surprisingly large!
Jan***************************
by jaymundayI dont have any way to scan so I will try to make this clear as possible. In my Y- axis Datum A (front face) Datum C ( large bore in center) datum D...
02-07-2012, 09:57 AM -
by NMC_CMMI'm no expert in GD&T, and I'd wager that my 'engineers' are not experts either.
Take a look at the attached file.
10-21-2009, 04:02 PM -
by JrcurvePlease help me.
I have a profile call like as ' surface profile 0.02|B|C|' . And the arrow is pointing datum A. What does that mean?. I don't understand...-
11-23-2017, 09:59 PM -
I have a group of cylinders that need to be reported for perpendicuality to the same datum with MMC. I report each feature (cylinder) with MMC to datum...
07-15-2009, 10:39 AM -
by Sl33stakI have a part we are going to be making. The datum structure is as follows. Plane1 = A
Centerline of a shaft hole = B
Centerline of the...-
02-01-2008, 11:14 AM -
