How do you measure a torus in PC-DMIS 4.1? I need to get a radius measurement on a "U" shaped 5" diameter tube.
Measuring a Torus
I didn't even know what a torus was until I looked here:
http://mathworld.wolfram.com/Torus.html
This may give you an idea???sigpic
PCDMIS 2012
Windows Office XP -
How is it dimensioned & toleranced? Is it just a simple profile tolerance or are radii and other features dimensioned?
Can you upload a sketch or something?sigpic
PCDMIS 2012
Windows Office XPComment
Measure it as a series of arcs and then construct a circle thru those centerlinesComment
Can you rotate the Coordinate system to match the given "Slice" that you are checking?Comment
Thats looks tough, but cant you just measure the U bend as a half circle? Your only concerned with the Radius of the bend right?
Otherwise I think your stuck having to level to each slice like cmmguy mentioned.Mr. Comment
SCIROCCO-NT 13-20-10
sigpicComment
This is turning out to be much harder than expected. The radius dimension is called out from the center axis of the tube so it looks like I am going to have to do the slice method. So far I have been unsuccessful with doing this.
Also, this part is too big to get on our largest CMM so I am left to use a portable (Romer) CMM. This could be why I am having so many problems with this measurement.Comment
by RodelaIs it possible to find the radius within a curved tube? Most callouts I've seen show the radius in the center of the tube and I'm not sure how to accurately...
Channel: PC-DMIS Portable
03-06-2018, 12:21 PM -
by AuRulesGot a tricky one fellows, how would you go about checking these 2 radius I have pictured in the attachment I need size and location. The bottom part of...
09-12-2013, 01:11 PM -
by traceeHopefully someone can help with this, I attached the drawing to this post.
How do you measure the bottom radius (70.079 +.001/-.000) in...-
07-26-2016, 01:36 PM -
by Jonathan SI need to measure a dimension to the centerline of a radius, but the radius is 2" and only covers an arc of about 25 degrees. Measured on the optical...
06-01-2006, 10:40 AM -
by BIG DANOI am measuring a 15 degree segment of a 72 inch radius and getting .200 oversize results, the profile was machined from the solid works model, which has...
11-01-2008, 09:59 AM -
