I need a little help trying to make this work.
We just recieved an Extended Force Module with a 5mm by 100mm Crabon Fiber probe and a 50mm Carbon Fiber Extension. I ordered these items so they will become a set. I will not use the module for anything but these probes and extn.
The problem I am having is this: The way I have it built up is as follows
PH10M, Convert 30mm to M8thread, TP20, Exten 90mm, Exten 10, tip 5mm by 50mm. This is the same way I build all my probes.
The reason for this build up is that I do not have a 50mm extension in my drop down window. I do not have a tip for 5mm by 100mm either.
When I go to calibrate the probe I get the message:
"Standard Deviations for probe calibration exceed limit."
I have the limit set for .0002.
Could it not be calibrating due to the build up? Any help would be great.
One thing I have done is after I try to calibrate the probe, I have gotten a 2.0000 ring gage and measured it. It is measureing within .0002-.0006.
Thanks
3.5MR2
Thanks
3.5MR2
