Hits
  • Hits
    When changing a scan to Surface Points, the initial and permanent default to 3 hits each. Where in thesettings editor is this default found?
    PC-Dmis 3.7 MR3
    PC-Dmis 3.7 MR3
    I think is an encrypted function (unable to change).
    sigpicIt's corona time!
      Change them first
      Before you change the scan to points, open the Surface point dialog and set the sample hits to 0. Create a Surface point, even if you delete it afterwards. I believe this will set the default the way you left it when you created the point from the dialog.
        That will work
        Thanks Don
