Hello all I have a feature that is a stud with a diameter. The stud has no flat diameter it is a radius up to a diameter. I have a crude drawing of it how can I measure this feature. I tried a .5mm probe and defined the top as a circle at 0 depth but that did not work. Thanks in advance I know one or two of you guru's will know. v3.7 mr3
incomplete radius
If that is all you need on the part, an optical comparitor would probably be your best bet. If you absolutely must measure it on the cmm, can you take hits around the "top" of the part to form a plane? Then, level that plane and make it your z-orgin. Create a circle with a z location of 0. Then, the tip should hit with the equator of the tip exactly at the level of the plane (plus or minus of course your machine's movement accuracy). Maybe that is what you tried.
by JLHUTTHelp, I have a part that is about 3.5" long (round) with an I.D of 1.5" in diameter. On one end of the I.D. there is a radius of 1.5",...
01-03-2008, 09:14 AM -
by AuRulesGot a tricky one fellows, how would you go about checking these 2 radius I have pictured in the attachment I need size and location. The bottom part of...
09-12-2013, 02:11 PM -
by JStewartI am trying to measure a very small internal radius and it's driving me crazy! The radius is .450 in the -X plane, but all I have to beep off of is about...
12-03-2010, 01:01 PM -
by Big Red
Two questions...
1) Please tell me how to inspect the 2.809 diameter on the CMM. This diameter is from the center of the...-
08-22-2007, 08:25 PM -
by bmeekCan the attached arc (colored green) be measured on the cmm? The radius is 1mm....
04-28-2020, 03:57 PM -
