I'm Drawing A Blank..... Need Some Quick Help.....i Have A Part That 20" X 20" X 1" Thick And Has A Few Holes Over The Entire Part. Found Out We Have A Catia Model For This Plate So I Had My Catia Guru Save It As A Iges File. Created A Program And Downloaded The Iges File, All Is Good So Far. Went And Check In Manual Mode The Features For The Alignment, Created The Alignment "so My Question Here Is Should I Use The Cad = Part Here After The Manual Or After The 1st Dcc And Do I Suppose To Use The Same Features That Created The Catia Alignment? What Is The Rules Of Ingagement Here I'm Drawing A Blank..........help
Cad=part
Cad=part
I'm Drawing A Blank..... Need Some Quick Help.....i Have A Part That 20" X 20" X 1" Thick And Has A Few Holes Over The Entire Part. Found Out We Have A Catia Model For This Plate So I Had My Catia Guru Save It As A Iges File. Created A Program And Downloaded The Iges File, All Is Good So Far. Went And Check In Manual Mode The Features For The Alignment, Created The Alignment "so My Question Here Is Should I Use The Cad = Part Here After The Manual Or After The 1st Dcc And Do I Suppose To Use The Same Features That Created The Catia Alignment? What Is The Rules Of Ingagement Here I'm Drawing A Blank..........helpsigpicTags: None
To help with the CAD = Part you better make sure before you start measuring you know where and how the orgins are set up on the model because that is the way you need to align it to use the CAD = part function.
You can only CAD = Part one time that I can think of not sure where Matt was coming from but heck we are at a 3 day high of 5 degrees!!
Before doing CAD = Part don't fret if the points are way off the model but after doing the CAD = Part it better be exactly where it needs to be.
3.7MR2
I think it's coming back...let's seeeee..... If I go and touch with my mouse in the graphic window and create the feature for the alignment and then run my part and manually touch my features I do not need cad = part. is that correct...sigpic
Originally posted by Johnson View PostTo help with the CAD = Part you better make sure before you start measuring you know where and how the orgins are set up on the model because that is the way you need to align it to use the CAD = part function.
Before doing CAD = Part don't fret if the points are way off the model but after doing the CAD = Part it better be exactly where it needs to be.sigpic
You do NOT need to do CAD=PART if you are doing an iterative alignment, it is 'included' in the iterative alignment. However, you CAN do so after the alignment and it will not hurt. I use CAD=PART for every alignment I make, in every program. Now, I am not saying that these 2 things are connected, but I also NEVER have an issue with nominals changing or move points going haywire.sigpic
Occasionally I choose to not use a CAD=PART or an iterative alignment when not using cad or when I'm measuring a pretty simple part. I simply transform the alignment to the part (you must have 4.0 or greater to transform). I then do a readpoint or read the CMM position. I translate to the readpoint and begin a DCC alignment from that starting point.sigpic
PCDMIS 2012
Windows Office XP
by Barry DawsonGday All,
If at the start of my program (offline4.2mr1 and using catia model) i do a manual iterative align then a dcc iterative...-
12-06-2007, 06:30 PM -
by AuRulesJust talking with a co-worker of mine and as the conversation went on it got a little heated. I was trying to explain to him If you have a catia model...
09-01-2009, 11:22 AM -
by eg92b16a2Good morning guru's.
Do you guys use CAD=PART after doing an alignment using the CAD model?
I read some where that I should not...-
03-01-2007, 10:56 PM -
Happy New Year to all ~
I was instructed back in Pc-dmis class that iterative alignment performs CAD='s PART as part of the alignment. I have...-
01-05-2008, 12:56 PM -
by operator1Hello and good morning. How are you guys and girls doing today? I'm great.
I have a problem followed by a quick question (tho it may...-
01-16-2008, 09:51 AM -
