Rotate at 1 Deg instead of 5 Deg
  • Rotate at 1 Deg instead of 5 Deg
    How does one have the Rotate Box permanently set at 1 Deg instead of 5 Deg??
    Thanks Gman
    sigpicThanks a Millionth
    Click on 1 every time you open it. There is no setting for it as far as I have ever found, at least, before I stopped looking for one.
      Matt,
      Would a template program with that step performed make the setting stick with code generated with the template as "starter" code?
      TK
      sigpicHave a homebrew
        Originally posted by tking View Post
        Matt,
        TK
        No, not sure if you are getting it, but he is talking (I THINK) about the 3-d view rotate, where you can use 1, 5, 10 or 45 degrees for single-click view rotate amounts. It always pops up at 5, no matter what.
          Stuck with 5 as a default here as well, as you said "no matter what".
          TK
            Yeah same here 5ยบ, I couldn't find anything in the PCDMIS.log file that indicated the ability to change it. Could be worse, it could come up with a paper clip or a dog.
              i gave up too, right click and drag...
              Loading...
