I am teaching myself to program, with a little help, and my help is on vacation. Can any one help explain move points, because I am having problems. For example, a simple 3-2-1 alignment on a block- after I do a manual align, I do a dcc align, moving the probe clear of the top plane and hitting the "print" button before doing the line for rotation. then moving the probe in the x until it clears the end of the block again, and do another "print" move point, before taking the second line, along the y axis Then I do a circle on the top plane, using the print button before and after probing the hole.But when I execute, the probe crashes.I did something similar but checking a hole using the minus y axisand a 90/180 probe, and even though I exaggerated the move point up to about 4" in Z, I had to stop the machine to prevent a crash. Any advice??
move points
Are all your move points and hit points from manual touch points with the joystick? Or were you using a CAD file and clicking on features?
I can think of a couple of things to look at first.
1. Check to make sure your Manual alignment is working correctly before switching into DCC.
2. Make sure your "active" probe is loaded and the probe tip is rotated in the correct direction.Mr. Comment
SCIROCCO-NT 13-20-10
Using the "print" button or ctrl+m will insert a move point with values equal to the values of the current probe location. If you want a move above a hole, position the probe above the hole and insert the move point. Hitting the "print" button may not be inserting move points. The "print" button's function can be changed on some machines. When you hit "print" I assume you can see in the edit window that a move point is inserted in your program. The move point will be inserted wherever your cursor is located in the program. If the cursor isn't where you want the move point it could cause a crashing issue.
Good luck, and run it slow until you are confident it isn't going to crash.
What everyone else has said. I would emphasize that you check to make sure the move points are where you expect them to be and/or even there. I've had several occasions where they were not recorded when I thought they were. One way to check is to save the program, close it and then reopen. I'm sure there are others.
Good luck, there is a lot of help available here.When the going gets weird, the weird turn pro. Hunter S. Thompson
Starting out easy is best if you are brand new. Go into the insert menu in PCDMIS and insert move points that way. Making sure you mark them for execution. Then start getting into the habit of CTRL-M.I used to be high on life but I built up a tolerance.
Originally posted by milul View PostI am teaching myself to program, with a little help, and my help is on vacation. Can any one help explain move points, because I am having problems. For example, a simple 3-2-1 alignment on a block- after I do a manual align, I do a dcc align, moving the probe clear of the top plane and hitting the "print" button before doing the line for rotation. then moving the probe in the x until it clears the end of the block again, and do another "print" move point, before taking the second line, along the y axis Then I do a circle on the top plane, using the print button before and after probing the hole.But when I execute, the probe crashes.I did something similar but checking a hole using the minus y axisand a 90/180 probe, and even though I exaggerated the move point up to about 4" in Z, I had to stop the machine to prevent a crash. Any advice??sigpic
It depends on which 3.7 you are talking about.
Clearance planes were not dependable in 3.7, 3.7 mr1, or 3.7 mr2.
I am now using 3.7 mr3 and they have shown to very dependable and actually work the way they are supposed to work.
I've never had a problem with them either, but then I don't use them.
Due to the shape / nature of my parts I use move points.
Manual alignment, then depending on complexity of the part, one or two dcc alignments. Use all move points, never a problem.
Just a different way of programming.
Regards,
ZydecoPetesigpic
In my humble opinion, clearplanes work just fine. I've not had many issues with using them, and I use them all the time. Only issue I've seen is that sometimes if you set a clearplane, measure some features, and realize that your clearplane wasn't enough, when you go back to change the value to a larger length, it seems to keep using the original value, even though it shows the new value.
The fix I use is to put a movepoint right before the first clearplane. Then it fixes itself from then on.
Weird. This may be fixed in 4.1 and 4.2.
I had issues in the earlier version of 3.7 where the move.clearplane would not move to the new clearplane setting until after one move.clearplane was initiated. Actually I got into the habit of using movepoints until I gave them another try in 3.7mr3, where they work as intended.
Milul I use the print button to create move points. On one of my cmm's it has a sharp 32 controller. This controller has had problems with getting the read position of the head right ever since I updated to a version of PCDMIS above ver 3.2063. I never had this problem before that version. Look at the xyz values after you create the move point to verify that what it writes into the program vs what the read position is at that time, and see if they are the same.
The only fix I have found for this is to edit the move points to get then to clear the part, or I use clearplanes. For me clearplane does not work for many of our parts because of the shape of the parts. (to many obsticles to avoid) I am running ver 3.7mr3 and I have not gone to 4.1 so I don't know if it works right in 4.1
If you have XYZ lets say in the front left corner of a block. With the probe beyond the left side of the block you should have (x-) value. The same should be true for the y axis also (y-) if you have the probe closer to you. The z axis will be (z+) when the probe is above the part.Time for the Trolls to leave.
by cesarhartWhat is the purpose of a move point on a program and how can I use it in a program that I am trying to create?
Is the move point for X,Y,Z?...-
08-08-2008, 02:00 AM -
by DarrollhHow do I set up move points? The part has been measured already. Thanks!!!!
01-04-2017, 09:45 PM -
Good morning folks. Time for Question of the day. I have gotten my books and have pieced together basic CAD programming from what I know from my Calypso...
08-20-2014, 10:06 AM -
by garnerjI am tring to add move points, and the software isn't letting me. I get hte audible tone but the move isn't inserted. I have tried from the remote as...
06-18-2013, 01:45 PM -
by DarrollHow do you set up move points on PCDMIS? I've used Romer and non DCC units before. Thanks for any help.
Sent from my HTC6500LVW using Ta...-
08-31-2015, 05:51 PM -
