Patch scan stalling
  • Patch scan stalling
    I've written several programs where I've seen this happen.
    When writing the program and executing single patch scans everything is fine.
    While running the entire program, the machine will stop at the beginning of a patch scan and just sit there.
    If I cancel out and press CNTRL U, it will continue as if everything is fine.
    Leitz Reference
    PC-DMIS V4.1
    I also tried this program on a Sheffield machine Saturday with the same results.
      Iv'e found that when I used to have that problem, it was because the computer didn't have the balls to crunch the numbers. Iv'e since then upgraded to a better computer and have not had that problem since.
        Leitz Reference
        PC-DMIS V4.1
        When this happens try this. Hit the stop button via your mouse, click continue. It should start it going again?
          I have the same problem in 4.1 but not when doing a scan. If I get a false probe hit or out of range error the machine will stop after correcting the error and do nothing. No way to correct it but re-execute or continue from the point??? Another reason I hate 4.1!!!
          PCDMIS 2012
          Windows Office XP
          • Tested
            4.1 scan?
            by Tested
            I have been running 4.1 sence it was released with no major problems, until now. I have brought 100's of programs up from V3.5 mr1 to V4.1. With little...
            06-15-2007, 06:52 AM
          • JEFMAN
            2017R1 32 bits: 2 little "bugs"
            by JEFMAN
            I have 2 problems with this version :
            Patch scan : when I create a patch scan, the cmm measure it, and at the end, I have a error message...
            03-16-2017, 05:51 AM
          • Robert Masters
            PC-DMIS Crash and burn ?
            by Robert Masters
            Does anyboy know if there are any special bugs that might cause my system to crash and burn right after performing a patch scan ?
            11-21-2007, 10:08 AM
          • Tridad
            Run Away Scan
            by Tridad
            Need some Scanning help here. I’m running a BS, Global Reference XI, with a B-4 controller. The software is PC-DMIS 2011, custom built for us. Using...
            11-04-2013, 12:14 PM
          • Tested
            Missing Scan
            by Tested
            I have mirrored a part program and all works well except for the scans. The program jumps right over them "it will not measure them at all"....
            01-09-2007, 07:09 AM
