Why when I run thru a program do my nominals keep changing. I go in put them to what I want and when it runs it changes it right back????
Global Image 3.7 MR2
C1 =COMMENT/YESNO,NO,Would you like to do a manual Alignment?
COMMENT/OPER,NO,For the Alignment use 4 hit on the v-block at
,each corner. 2 hits on the front edge running
,left to right. and 2 hits on the right side of the
,v-block front to back make sure to take the
,hits on the right side high enough to not hit
,the shank on the probe.
IF/C1.INPUT == "YES"
PLN1 =FEAT/PLANE,RECT,TRIANGLE
THEO/376.005,101.596,-436.656,-0.0002176,0.0045756,0.9999895
ACTL/374.085,101.166,-436.98,0.0000492,0.0092878,0.9999569
MEAS/PLANE,4
HIT/BASIC,NORMAL,317.138,77.106,-436.416,-0.0002176,0.0045756,0.9999895,312.702,75.689,-436.886,USE THEO = YES
HIT/BASIC,NORMAL,434.863,77.118,-436.672,-0.0002176,0.0045756,0.9999895,436.146,75.7,-436.602,USE THEO = YES
HIT/BASIC,NORMAL,434.862,126.085,-436.615,-0.0002176,0.0045756,0.9999895,436.147,126.643,-437.363,USE THEO = YES
HIT/BASIC,NORMAL,317.157,126.074,-436.921,-0.0002176,0.0045756,0.9999895,311.346,126.632,-437.071,USE THEO = YES
ENDMEAS/
LIN1 =FEAT/LINE,RECT,UNBND
THEO/317.157,71.893,-439.134,0.9999868,-0.0051356,0
ACTL/312.355,71.992,-440.37,0.9999767,-0.0068191,0
MEAS/LINE,2,WORKPLANE
HIT/BASIC,NORMAL,317.157,71.893,-439.134,-0.0051356,-0.9999868,0,312.355,71.992,-440.37,USE THEO = YES
HIT/BASIC,NORMAL,438.159,71.271,-439.137,-0.0051356,-0.9999868,0,438.116,71.135,-440.375,USE THEO = YES
ENDMEAS/
LIN2 =FEAT/LINE,RECT,UNBND
THEO/441.808,77.569,-439.143,0.0119318,0.9999288,0
ACTL/441.171,77.319,-440.375,0.0118097,0.9999303,0
HIT/BASIC,NORMAL,441.808,77.569,-439.143,0.9999288,-0.0119318,0,441.171,77.319,-440.375,USE THEO = YES
HIT/BASIC,NORMAL,442.354,123.302,-439.143,0.9999288,-0.0119318,0,441.763,127.457,-440.375,USE THEO = YES
ENDMEAS/
PNT1 =FEAT/POINT,RECT
THEO/441.733,71.253,-439.138,0.9999868,-0.0051356,0
ACTL/441.098,71.114,-440.373,0.9999767,-0.0068191,0
CONSTR/POINT,INT,LIN1,LIN2
A1 =ALIGNMENT/START,RECALL:STARTUP, LIST= YES
ALIGNMENT/LEVEL,ZPLUS,PLN1
ALIGNMENT/ROTATE,XPLUS,TO,LIN1,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,PNT1
ALIGNMENT/TRANS,YAXIS,PNT1
ALIGNMENT/TRANS,ZAXIS,PLN1
ALIGNMENT/END
MOVE/POINT,NORMAL,5.373,51.786,58.26
END_IF/
MODE/DCC
FORMAT/TEXT,OPTIONS,ID,HEADINGS,SYMBOLS, ;NOM,TOL,MEAS,MAXMIN,DEV,DEVANG,OUTTOL
ACCELERATION/MAXACCELX=1500, MAXACCELY=1500, MAXACCELZ=500
CLEARP/ZPLUS,25.4,ZPLUS,0
C2 =COMMENT/YESNO,NO,Would you like to do an auto alignment?
IF/C2.INPUT == "YES"
COMMENT/OPER,NO,The CMM will now move auto!!!
PLN2 =FEAT/PLANE,RECT,TRIANGLE
THEO/-68.241,30.477,-0.019,0.0001309,-0.0028363,0.999996
ACTL/-68.24,30.482,0.615,-0.0002813,-0.0091524,0.9999581
MEAS/PLANE,4
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-128.594,5.369,-0.189,0.0001309,-0.0028363,0.999996,-128.594,5.367,0.369,USE THEO = YES
HIT/BASIC,NORMAL,-7.562,5.251,0.007,0.0001309,-0.0028363,0.999996,-7.562,5.251,0.401,USE THEO = YES
HIT/BASIC,NORMAL,-7.823,55.961,-0.06,0.0001309,-0.0028363,0.999996,-7.823,55.96,0.866,USE THEO = YES
HIT/BASIC,NORMAL,-128.984,55.326,0.167,0.0001309,-0.0028363,0.999996,-128.985,55.326,0.825,USE THEO = YES
ENDMEAS/
LIN3 =FEAT/LINE,RECT,UNBND
THEO/-128.698,0.306,-4.287,0.9999989,-0.0015052,0
ACTL/-128.705,-0.353,-4.28,0.9999997,0.0008275,0
MEAS/LINE,5,WORKPLANE
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-128.697,0.61,-4.286,-0.0015052,-0.9999989,0,-128.703,-0.356,-4.279,USE THEO = YES
HIT/BASIC,NORMAL,-94.01,0.137,-4.297,-0.0015052,-0.9999989,0,-94.012,-0.322,-4.289,USE THEO = YES
HIT/BASIC,NORMAL,-72.223,-0.195,-4.304,-0.0015052,-0.9999989,0,-72.222,-0.302,-4.295,USE THEO = YES
HIT/BASIC,NORMAL,-30.985,0.202,-4.313,-0.0015052,-0.9999989,0,-30.989,-0.272,-4.306,USE THEO = YES
HIT/BASIC,NORMAL,-2.432,0.3,-4.32,-0.0015052,-0.9999989,0,-2.434,-0.25,-4.311,USE THEO = YES
ENDMEAS/
LIN4 =FEAT/LINE,RECT,UNBND
THEO/0.246,3.296,-4.303,-0.0021614,0.9999977,0
ACTL/0.971,3.297,-4.295,-0.0008452,0.9999996,0
MEAS/LINE,4,WORKPLANE
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,0.153,3.296,-4.303,0.9999977,0.0021614,0,0.971,3.296,-4.295,USE THEO = YES
HIT/BASIC,NORMAL,0.335,9.653,-4.274,0.9999977,0.0021614,0,0.965,9.654,-4.267,USE THEO = YES
HIT/BASIC,NORMAL,0.174,50.652,-4.087,0.9999977,0.0021614,0,0.931,50.655,-4.08,USE THEO = YES
HIT/BASIC,NORMAL,0.092,56.969,-4.057,0.9999977,0.0021614,0,0.925,56.971,-4.051,USE THEO = YES
ENDMEAS/
PNT2 =FEAT/POINT,RECT
THEO/0.253,0.112,-4.295,0.9999989,-0.0015052,0
ACTL/0.974,-0.245,-4.288,0.9999997,0.0008275,0
CONSTR/POINT,INT,LIN3,LIN4
MOVE/POINT,NORMAL,4.394,56.656,69.878
A2 =ALIGNMENT/START,RECALL:A1, LIST= YES
ALIGNMENT/LEVEL,ZPLUS,PLN2
ALIGNMENT/ROTATE,XPLUS,TO,LIN3,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,PNT2
ALIGNMENT/TRANS,YAXIS,PNT2
ALIGNMENT/TRANS,ZAXIS,PLN2
ALIGNMENT/END
END_IF/
COMMENT/OPER,NO,The CMM will now run the pieces. Put 3 pieces
,in the v-block Datum B to the right flush with
,the right side of the v-block ears straight up
,and down, with a square spacers between them.
,Remove the spacers before measuring.
L1 =LABEL/
C3 =COMMENT/INPUT,NO,'How many pieces do you want to run in a
,row? Max of 3'
ASSIGN/LOOPINDEX = 1
V2 =LOOP/START, ID = YES, NUMBER = C3.INPUT, START = 1, SKIP = ,
OFFSET: XAXIS = -54.75, YAXIS = 0, ZAXIS = 0, ANGLE = 0
MOVE/POINT,NORMAL,-4.637,35.676,69.796
STATS/ON,DATAPAGE,$
DIRECTORY=C:\DATAPAGE\DELPHI\4005,$
DIRECTORY=,$
READ=10,WRITE=20,MEMPAGES=64,DIMENSION NAME,CONTROLCALC OFF,$
STATS/END
PREHIT/ 1
RETRACT/ 1
LIN5 =FEAT/LINE,RECT,UNBND
THEO/-2.71,39.346,22.091,-0.0020282,-0.9999979,0
ACTL/-3.278,39.351,22.092,-0.0002207,-1,0
MEAS/LINE,8,WORKPLANE
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-2.7,39.463,19.848,-0.9999979,0.0020282,0,-3.272,39.466,19.854,USE THEO = YES
HIT/BASIC,NORMAL,-2.684,35.622,21.963,-0.9999979,0.0020282,0,-3.279,35.627,21.963,USE THEO = YES
HIT/BASIC,NORMAL,-2.786,32.739,22.98,-0.9999979,0.0020282,0,-3.284,32.741,22.98,USE THEO = YES
HIT/BASIC,NORMAL,-2.782,29.783,22.975,-0.9999979,0.0020282,0,-3.285,29.784,22.976,USE THEO = YES
HIT/BASIC,NORMAL,-2.676,26.662,22.969,-0.9999979,0.0020282,0,-3.284,26.663,22.97,USE THEO = YES
HIT/BASIC,NORMAL,-2.685,23.458,21.883,-0.9999979,0.0020282,0,-3.283,23.459,21.889,USE THEO = YES
HIT/BASIC,NORMAL,-2.772,20.965,20.513,-0.9999979,0.0020282,0,-3.281,20.966,20.522,USE THEO = YES
HIT/BASIC,NORMAL,-2.772,19.511,19.095,-0.9999979,0.0020282,0,-3.278,19.512,19.104,USE THEO = YES
ENDMEAS/
LIN6 =FEAT/LINE,RECT,UNBND
THEO/-6.536,19.194,20.942,-0.0045656,0.9999896,0
ACTL/-6.904,19.193,20.942,0.0003078,1,0
MOVE/CLEARPLANE
HIT/BASIC,NORMAL,-6.55,19.291,19.232,0.999903,0.0139273,0,-6.899,19.3,19.24,USE THEO = YES
HIT/BASIC,NORMAL,-6.52,21.138,20.478,0.999903,0.0139273,0,-6.902,21.148,20.477,USE THEO = YES
HIT/BASIC,NORMAL,-6.548,22.814,21.402,0.999903,0.0139273,0,-6.904,22.827,21.402,USE THEO = YES
HIT/BASIC,NORMAL,-6.579,25.02,22.467,0.999903,0.0139273,0,-6.906,25.035,22.466,USE THEO = YES
HIT/BASIC,NORMAL,-6.618,28.497,23.163,0.999903,0.0139273,0,-6.906,28.514,23.163,USE THEO = YES
HIT/BASIC,NORMAL,-6.538,32.928,23.016,0.999903,0.0139273,0,-6.899,32.943,23.02,USE THEO = YES
HIT/BASIC,NORMAL,-6.607,35.965,22.06,0.999903,0.0139273,0,-6.901,35.981,22.069,USE THEO = YES
HIT/BASIC,NORMAL,-6.654,39.122,20.167,0.999903,0.0139273,0,-6.893,39.139,20.175,USE THEO = YES
ENDMEAS/
MOVE/POINT,NORMAL,-5.48,39.07,45.304
ASSIGN/LOOPINDEX = LOOPINDEX + 1
DIM DIST1= 2D DISTANCE FROM LINE LIN5 TO LINE LIN6 (CENTER TO CENTER), NO_RADIUS UNITS=MM ,$
AX NOMINAL +TOL -TOL MEAS MAX MIN DEV OUTTOL
M 3.861 0.035 0.035 3.631 10.981 3.680 -0.230 0.195 <--------
LOOP/END
MOVE/POINT,NORMAL,-114.739,37.669,81.865
MOVE/POINT,NORMAL,12.776,96.459,81.86
COMMENT/OPER,NO,Place next 3 pcs on v-block
GOTO/L1
MEAS/PLANE,4
ENDMEAS/
ENDMEAS/
ENDMEAS/
ALIGNMENT/END
END_IF/
MODE/DCC
MEAS/PLANE,4
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
ALIGNMENT/END
END_IF/
L1 =LABEL/
,row? Max of 3'
STATS/ON,DATAPAGE,$
DIRECTORY=,$
STATS/END
PREHIT/ 1
RETRACT/ 1
MOVE/CLEARPLANE
ENDMEAS/
MOVE/CLEARPLANE
ENDMEAS/
LOOP/END
GOTO/L1
