Hello,
I dont know what I'm doing or how to program... But, I need to measure 100 small parts at a time all the time. I wrote a program that will measure 1 part and I'd like to be able to measure a part, switch to the next part in the same exact location and hit enter and the cmm measures the new part 100 times in a row and then prints a report with inside radius, outside radius and thickness. Is this possible and explainable in the forum? Here is what I got so far.
Thanks
STARTUP =ALIGNMENT/START,RECALL:,LIST=YES
ALIGNMENT/END
MODE/MANUAL
LOADPROBE/5000-3603
COMMENT/OPER,NO,Measure Plane (4 Hits)
PLN1 =FEAT/PLANE,RECT,TRIANGLE
THEO/15.3965,14.3114,-26.1579,-0.0000925,-0.0000173,1
ACTL/16.3595,14.3082,-26.1581,-0.0000727,-0.0000203,1
MEAS/PLANE,4
HIT/BASIC,NORMAL,18.7642,17.3703,-26.1574,-0.0000925,-0.0000173,1,19.5944,11.3939,-26.1579,USE THEO = YES
HIT/BASIC,NORMAL,12.1662,17.37,-26.1582,-0.0000925,-0.0000173,1,13.3336,11.3937,-26.1583,USE THEO = YES
HIT/BASIC,NORMAL,12.1661,11.2525,-26.1581,-0.0000925,-0.0000173,1,13.2015,17.2224,-26.1583,USE THEO = YES
HIT/BASIC,NORMAL,18.4896,11.2527,-26.1577,-0.0000925,-0.0000173,1,19.3086,17.2228,-26.1577,USE THEO = YES
ENDMEAS/
COMMENT/OPER,NO,Measure Front Left Circle
,(3 Hits)
CIR1 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/11.6737,17.9571,-26.2311,0,0,1,0.5011
ACTL/12.631,17.9581,-26.2481,0,0,1,0.5009
MEAS/CIRCLE,3,WORKPLANE
HIT/BASIC,NORMAL,11.622,18.1998,-26.2311,0.3005709,-0.9537595,0,12.6504,18.2078,-26.2481,USE THEO = YES
HIT/BASIC,NORMAL,11.9167,18.0078,-26.2311,-0.955704,-0.2943295,0,12.8805,17.9796,-26.2481,USE THEO = YES
HIT/BASIC,NORMAL,11.4308,18.0078,-26.2311,0.9557252,-0.2942606,0,12.3814,17.9796,-26.2481,USE THEO = YES
ENDMEAS/
COMMENT/OPER,NO,Measure Rear Left Circle
,(3 Hits)
CIR2 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/18.6736,17.9032,-26.2127,0,0,1,0.5018
ACTL/19.6311,17.9442,-26.269,0,0,1,0.5014
HIT/BASIC,NORMAL,18.667,18.1498,-26.2126,0.1487479,-0.9888751,0,19.5214,18.1696,-26.2689,USE THEO = YES
HIT/BASIC,NORMAL,18.9245,17.9044,-26.2127,-0.9999755,-0.0069974,0,19.8732,17.879,-26.269,USE THEO = YES
HIT/BASIC,NORMAL,18.435,17.8264,-26.2127,0.9423774,0.3345518,0,19.389,17.879,-26.269,USE THEO = YES
ENDMEAS/
COMMENT/OPER,NO,Machine Going into DCC Mode !
ALIGNMENT/LEVEL,ZPLUS,PLN1
ALIGNMENT/ROTATE_CIRCLE,XPLUS,TO,CIR2,AND,CIR1,ABOUT,ZPLUS
ALIGNMENT/TRANS,XAXIS,CIR2
ALIGNMENT/TRANS,YAXIS,CIR2
ALIGNMENT/TRANS,ZAXIS,PLN1
ALIGNMENT/END
MODE/DCC
MOVE/POINT,NORMAL,0.0247,0.0597,1.2333
PLN2 =FEAT/PLANE,RECT,TRIANGLE
THEO/1.2921,5.1875,0.2789,0.0000754,0.0000262,1
ACTL/1.2922,5.1874,0.2816,0.0008863,-0.0000255,0.9999996
MEAS/PLANE,4
HIT/BASIC,NORMAL,0.3866,4.9561,0.279,0.0000754,0.00002 62,1,0.3865,4.9559,0.2824,USE THEO = YES
HIT/BASIC,NORMAL,2.0796,4.1494,0.2789,0.0000754,0.0000 262,1,2.0795,4.1497,0.2809,USE THEO = YES
HIT/BASIC,NORMAL,2.0675,5.8273,0.2788,0.0000754,0.0000 262,1,2.0678,5.8271,0.281,USE THEO = YES
HIT/BASIC,NORMAL,0.6347,5.8169,0.279,0.0000754,0.00002 62,1,0.6352,5.817,0.2822,USE THEO = YES
ENDMEAS/
MOVE/POINT,NORMAL,1.4194,5.0502,0.5131
1.510 CIR3 =FEAT/CIRCLE,RECT,IN,LEAST_SQR
THEO/1.4276,5,0.1567,0,0,1,1.51
ACTL/1.4199,4.9973,0.1569,0,0,1,1.5117
MEAS/CIRCLE,8,WORKPLANE
HIT/BASIC,NORMAL,2.1826,5,0.1567,-1,0,0,2.1757,5.0004,0.157,USE THEO = YES
HIT/BASIC,NORMAL,1.9615,5.5339,0.1567,-0.7071068,-0.7071068,0,1.9572,5.529,0.1569,USE THEO = YES
HIT/BASIC,NORMAL,1.4276,5.755,0.1567,0,-1,0,1.4285,5.7532,0.1569,USE THEO = YES
HIT/BASIC,NORMAL,0.8937,5.5339,0.1567,0.7071068,-0.7071068,0,0.891,5.5373,0.1569,USE THEO = YES
HIT/BASIC,NORMAL,0.6726,5,0.1567,1,0,0,0.664,5.0003,0. 1569,USE THEO = YES
HIT/BASIC,NORMAL,0.8937,4.4661,0.1567,0.7071068,0.7071 068,0,0.888,4.4602,0.1569,USE THEO = YES
HIT/BASIC,NORMAL,1.4276,4.245,0.1567,0,1,0,1.4281,4.24 15,0.1569,USE THEO = YES
HIT/BASIC,NORMAL,1.9615,4.4661,0.1567,-0.7071068,0.7071068,0,1.9599,4.4685,0.1569,USE THEO = YES
ENDMEAS/
MOVE/POINT,NORMAL,1.3201,5.08,0.5481
MOVE/POINT,NORMAL,-0.4748,5.0067,0.5478
2.99 CIR3 =FEAT/CIRCLE,RECT,OUT,LEAST_SQR
THEO/1.4271,4.9999,0.1625,0,0,1,2.99
ACTL/1.4206,4.9972,0.1628,0,0,1,2.9914
HIT/BASIC,NORMAL,-0.0679,4.9999,0.1625,-1,0,0,-0.0755,5.0001,0.1628,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,0.37,3.9428,0.1625,-0.7071068,-0.7071068,0,0.3652,3.9375,0.1628,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,1.4271,3.5049,0.1625,0,-1,0,1.4271,3.5022,0.1629,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,2.4842,3.9428,0.1625,0.7071068,-0.7071068,0,2.482,3.945,0.1628,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,2.9221,4.9999,0.1625,1,0,0,2.915,4.99 96,0.1628,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,2.4842,6.057,0.1625,0.7071068,0.70710 68,0,2.4803,6.0529,0.1628,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,1.4271,6.4949,0.1625,0,1,0,1.4276,6.4 93,0.1627,USE THEO = YES
MOVE/CIRCULAR
HIT/BASIC,NORMAL,0.37,6.057,0.1625,-0.7071068,0.7071068,0,0.3677,6.0594,0.1627,USE THEO = YES
ENDMEAS/
MOVE/POINT,NORMAL,-1.0391,4.2002,0.802
DIM LOC1= LOCATION OF CIRCLE 1.510 CIR3 UNITS=IN ,$
R 0.7550 0.0050 0.0050 0.7559 0.0009 0.0000 -----#---
END OF DIMENSION LOC1
DIM LOC2= LOCATION OF CIRCLE 2.99 CIR3 UNITS=IN ,$
R 1.4950 0.0050 0.0050 1.4957 0.0007 0.0000 -----#---
END OF DIMENSION LOC2
DIM DIST1= 3D DISTANCE FROM PLANE PLN1 TO PLANE PLN2, NO_RADIUS UNITS=IN ,$
M 0.2800 0.0075 0.0075 0.2800 0.0000 0.0000 ----#----
Thanks
ALIGNMENT/END
MODE/MANUAL
LOADPROBE/5000-3603
MEAS/PLANE,4
ENDMEAS/
,(3 Hits)
ENDMEAS/
,(3 Hits)
ENDMEAS/
ALIGNMENT/END
MODE/DCC
MEAS/PLANE,4
ENDMEAS/
ENDMEAS/
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
MOVE/CIRCULAR
ENDMEAS/
