I get this error message in DCC mode: TR_min2 Machine Parameters
Larger Than Permitted. Machine stops.First I do a regular plane, line, line alighnment in manual mode then i go into DCC mode set the clearance plane
i then do a second alignment same as the first but with more points when i go to run the second alignment in DCC mode i get that message and the machine stops.sometimes it will also say ( tip will be driven into the table ) I suspect something has changed in the machines Z envelope.
