Hi everyone, I am new to this board and PD-DMIS. I need some help please. I have been using a PC-DMIS for several months. In the past I have routinely created a line from to constructed points, but now for some reason I get math failed: Combination of input features not supported. Have I shut some setting off??? I measured a part yesterday and could not construct the line, I re-measured the part today and could not construct the line, and then I measured a different part and still have the same problem. The program will let me construct a line between to hit points, but not constructed points.
Math Failed Question
Welcome Durose. Creation of lines is very dependant on workplanes. If you need to create a line using the x and y coordinates then you need to be in the Z workplane.
http://www.box.net/public/static/uz5zvfb5gi.jpgsigpic
Originally posted by bw_bob View PostIf your probe orientation is A0,B0 then you will need to look at it in Y -or+ worlplane
or X -or+ workplane and then construct the line. I hope this makes sensesigpic
Here are the coordinates Craiger
PNT5 =FEAT/POINT,RECT
THE0/0,0,20.9047,0,0,1
ACTL/-9.996,0.0736,0.0324,0,0,1
CONSTR/POINT,PROJ,CIR3,PLN2
PNT6 =FEAT/POINT,RECT
ACTL/-10.3479,-47.4481,0.0324,0,0,1
CONSTR/POINT,PROJ,CIR4,PLN2
They have the same nominal location so PCDMIS can not make a line that nominally has no length therefore no vector. It does not know what direction the line should point in a generic sense.
What do you intend to do with this line? We might be able to help you achieve your goal but right now it is not doable with this line.
Hi Matthew, actually the machine is a Roamer and I work with large welded assemblies which distort and twist due to weld. A lot of times I will due a temp alignment, measure the entire unit and then later try to construct an alignment which makes sense. Usually this approach works.
Originally posted by Durose View PostHi Matthew, actually the machine is a Roamer and I work with large welded assemblies which distort and twist due to weld. A lot of times I will due a temp alignment, measure the entire unit and then later try to construct an alignment which makes sense. Usually this approach works.sigpic
by dtmtimIt sounds like such a simple thing. Create a line between 2 intersection points. I have done this hunderds of times using vector points but for some...
12-07-2006, 10:09 AM -
by tnguyenHi. Could anybody instructs me how to measure a line to apply for Straightness dimension ?.
I read in the Manual Referrence. It says the line...-
05-08-2006, 12:15 AM -
by RyanKrallI used an auto-line to measure a feature and want to construct a line from the two highest points. How do I go about doing this? If I'm not mistaken,...
Channel: PC-DMIS Vision
04-29-2019, 04:12 PM -
by sleepystarzHello, first post here. Our CMM operator has left and they've thrown me into the mix after 1 week of training. I'm learning a lot but still have a ways...
03-07-2007, 11:06 AM -
by kevracWhat are the differences taking a 3D line vs a workplane line? I have always used workplane and switch my plane to get lines in the view I need switching...
06-10-2010, 03:19 PM -
