I created a free form scan with 7 initial hits around a 2" x 5" pad. Over a thousand + hits should be taken when scanned using the sp25. When I try to construct a plane using just this one scan, I get an error " meas math failed, must have at least 3 points. I have a thousand points. I know it wants at least three individual points, but I have over a thousand hits inside this one scan. I can just answer yes to the command and it will construct the scan with just the one entry, is this OK. Any comments? Suggestions?
Construct Plane from Freeform Scan = Meas math math failed
Well, a scan if left as a 1-entity unit IS really only '1 point', however, you CAN break the scan into individual points, then you can construct a set from those point to 'simulate' the scan for dimensioning porposes (I don't like dolphins!), but then you are back to touch-type hits instead of the continuouse scan. What it is doing when constructing the plane from the scan is really kind of a mystery, unless you do some testing to find out what it is actually doing.sigpic
by Steve RHi all, if i convert my scan into points , can I convert the points back to a can (using TP, prode)
07-04-2017, 12:44 PM -
by Tomi530iGood morning all
I have a nooby question.
When I'm using auto feature I can change the measurement strategies to Adaptive Scan...-
02-08-2016, 07:19 AM -
by robehor4Is there a way to use Grid scan with a SM25 scan head and not use points but maintain constant contact?
09-19-2007, 03:03 PM -
by rrowsamHey Guys,
So I'm writing a pretty large program that needs to check a bunch of contours. I think I can measure many of them with one scan....-
11-30-2017, 05:36 PM -
Hi Guys
I am looking for some help taking points from a patch scan and then reporting them again.
All I am looking for...-
11-26-2015, 10:48 AM -
