I forgoten again..... If the T value is plus you have to much stock?
T Value?
It is 'heavy' or TOWARDS the probe's 'starting' position when it goes to make the touch. If you have a sheet metal part, sitting of a fixture, it simulates a feeler check, + means the part is away from the fixture, or that you can put in the nominal feeler check amount + the T value.sigpic
found it....
Assuming that the surface normal vector is pointing away from the surface on which the nominal point lies, a positive value of T means that the material is too “high” while a negative value of T means that the material is too “low”.
by venkat9Can any one explain me the caluculation of "T" value..
02-28-2013, 08:16 AM -
by dwadeI read a post this week or last explaining the T value. Tried to search but had no luck.
Could someone explain it again. Trying to...-
08-23-2006, 09:58 AM -
by Steve RHello everyone, I have a forging 36inches by 24inches and 13inches in depth, should be .300 of extra material all around. I have a dimension...
11-09-2016, 10:24 PM -
by keithWell, I thought I had DataPage on the computer, but apparently it's not licensed. I get a missing authorization code error.
At any rate,...-
09-05-2006, 03:14 PM -
by StoneThrowerhello again gents,
I have been tasked and asked to report the "T" value for points taken on the specimen. this is not an issue,...-
03-21-2016, 08:27 AM -
