I programmed a part offline from the CAD model while I waited for the actual part to be manufactured. I received the part and was instructed that all I would need to do is put the part onto the machine, do a manual and dcc alignment, and my program should be good to go as I didn't have any collisions showing up on the offline program.
My problem is that I have the part on the machine and the first thing that happened was my tip that was first to be used crashed into the part, but not on the CAD model. To troubleshoot, I opened a "New" file, changed the tip being used, performed new alignments manual and DCC, then cut and pasted the body of my program. My program showed that it updated all of the command below the alignments, but the program still does not want to function. Upon the first move to the part, it said that is is out of tolerance and to move the probe. Also, I thought that perhaps I needed to do a CAD equals Part since I imported the part, but that button didn't show up in my alignment window.
Are there any suggestions to how to fix this or will I have to start a new program from scratch online?
