TRUE POSITION FROM HOLE PATTERN
  • TRUE POSITION FROM HOLE PATTERN
    I have 6 .2500 holes that make up datum -D-
    I have 2 .1250 holes with a true position of .005 MMC from -D-
    What is the best way to create an origin point from the 6 .2500 holes
    Thanks
    Can we see a pic? I would like to see -D- on the print.
      I'd construct a circle from the 6 circles(holes). Make that an origin. Dimension location (TP) from there.
        I agree with John, center of the best fit circle as origin. Just watch out for rotation. If it is diametral TP you may need a rotation feature.
        James Temmen
          the holes are in a rectangular pattern not circular
            You can always do a 2D best fit using all 6, or construct a feature set from them and use the mathmatical center as the origin.
            James Temmen
              Can you scan that section and insert?
                Thanks for the help
                always appreciated
                  Cool that seems to work
                  i created a constructed set which came up as scan1
                  then i used scan1 as x y zero in new alignment
                  thanks again
                    Feature set is the way I'd go too. Kudos to JTenemen.
